David.
Are you using the same output from the LNB on your sky dish?
ie one cable??.
If you are it will not work you need to use a seperate output,
if you cant do this,you will need to change the LNB to a multi output one.
By the way there is 30 volts present all the time from your receiver to your LNB, that is even while switched off.
SOURCE: how do you tune in
You require a satelite decoder/receiver for your dish and an aerial for your TV.
The choice is yours. Plug a satelite receiver, for freesat, into the A/V input on the TV or have an aerial installed for freeview.
SOURCE: I have a Panasonic TH-P42S10Z
You can't connect your TV direct to the dish. It needs to be connected to a sky decoder to be used.
If you've got Freeview built in to your TV you'll need to have an external aerial fitted if one isn't already their.
Is their an external aerial and I'l look into the setup procedure for tuning the TV.
SOURCE: Panasonic tx32lxd60 to freeview hd?
Buy a seperate HD box. It is possible, but more hassle than it is worth ( and more expensive)The tuner board is only available from Panasonic.
