Machine worked when put into storage now is locked up. Motor tries to work but needle will not move up and down
The oil has dried out while in storage and the moving parts are frozen. I use liquid Tri-Flow Synthetic Oil. Open the top of the machine and put two drops of oil every place that metal rubs against metal. Gently hand rotate the handwheel to see how things move. (Probably shouldn't oil any plastic parts.) Then do the same in the bobbin area. If it is really stuck, use a handheld hair dryer and direct hot air into the top and bottom of the machine.
Once it is working again, be sure to clean and oil on a regular basis--at least every six months if it's not in use. When in use, oil and clean every 40 hours of constant sewing.
Sewing machines need to be worked periodically even if you aren't sewing a lot. The oils and greases inside get all gummed up and literally will seize them up. Your best bet is to take it to the pro, pay the $$$ and have them, clean, oil, grease, replace belts, and adjust. OR if you want to give it a try.. DIY... kerosene based cleaner. Clean it well, then oil it properly. Make sure the machine is UNPLUGGED while cleaning.
SOURCE: my machine has power, but foot pedal only makes needle go slowly
sounds like the contact in the foot peddle has failed try a new peddle
SOURCE: necchi 534FB
I solved this problem for a friend,!. the needle was in the wrong way and
2 the bobbin case was not properly seated be sure you hear the 'click 'when
reinserting the bobbin case...hope this is helpful Velz
SOURCE: Necchi Model 535 FA
Hi! The motor pulley may be worn and cant turn properly causing the motor to be forced so much. The result will be an instant overheating that results to belt burn too. You will need to replace the motor, pulley and the belt now to make it running. Hope this helps and have a good one!
SOURCE: sewing machine needle is stuck and the machine will not move.
you should go with the flow, just take a deep breath hayete w byemshe el hal
SOURCE: Where to put the oil for a Necchi Lydia 3 sewing machine
Beldia 1306 - did you ever solve your sewing m/c problem. I have just resurrected my old Necchi and have the same problem, power but very sluggish operation of the needle, could be oil that is needed. Can you help?
