SOURCE: cant save to pdf in printmaster gold 17
found the fix for printmaster 18 broderbund pdf saving problems...
1-close all open programs and return to desktop.
2-click START and choose CONTROL PANEL
3-click PRINTER
4-right click on BRODERBUND PDF CREATER, then select PROPERTIES (the broderbund PDF creater properties window will open)
5-click the PORTS tab, then select ADD PORT button. (the printer ports window will open)
6-click NEW PORT, then enter PMPDF in the ENTER A PORT NAME window, then click OK
7-click CLOSE at the PRINTER PORTS window. you will now be looking at the broderbund PDF creater properties window
8-a check mark will be located next to the new PMPDF printer port. click APPLY. the broderbund pdf creator will now be located next to the new port. click OK.
9-exit all windows and restart the computer. once the computer restarts, you can save your project as a pdf file.
SOURCE: Installing a new verison of Printmaster
No,pm18 wil over come pm10 in ur comp OR uninstall the Pm10
SOURCE: I have purchased PrintMaster Gold version 18 three
You might have a problem with your CD/DVD drive. Try inserting the CD in another computer. If the files are shown, replace your CD/DVD drive or just add another CD drive to an empty bay of your computer.
SOURCE: Printmaster 10 was on my old gateway computer
As I just posted on http://www.fixya.com/support/t2129564-printmaster_platinum_10_version_will_not I was able to get PrintMaster Platinum 10 to install on Windows Vista by right clicking on E:\Setup\is_Setup.Exe->Properties->Compatibility->Run this program in compatibility mode for Windows XP (Service Pack 2) and then running E:\Setup>is_Setup.Exe FullSetup.ini from the command prompt.
SOURCE: I have used PrintMaster 10
The only solution with this older software that will work is to use a computer (virtual, dual-boot, or true second machine) with an older version of Windows installed. If you have Win7 Pro or Ultimate (or are willing to upgrade to one of these versions), you can create a virtual XP computer for free. Download and install Virtual PC and XP mode from Microsoft. Install them in order. Then install the XP software in the virtual computer and it will work. (Other virtual computer programs are Parallels and VMWare.) All of the other options will require a licensed version of the older Windows OS. Please note that the virtual computer can't share files directly with the main computer. You'll need to save files to external or removable media (optical media or flash drive, for example) to share them. You can't have a printer installed on both the main computer and the virtual one at the same time. You will be asked to uninstall the printer if you try.
Your other option is to upgrade to PrintMaster Platinum 18.1, see http://www.broderbund.com/ for details, which is compatible with Windows 7. This will import your Printmaster 10 projects.
I hope this helps.
Testimonial: "Thanks for your help. I will investigate purchasing Printmaster 18.1."
