Remington 16 inch chain saw
SOURCE: replancement bar for 16 inch remington chain saw
The bar is the piece of metal that the chain goes around. This link has lots of info on your saw http://www.remingtonchainsaw.com/chainsaw.html
SOURCE: replacing Remington Electric chain saw blade
Where the bar meets the body of the saw there is an adjustment lug that will either push the bar outward tightening the chain or may be retracted allowing slack in the chain. When backed off (loosened) sufficiently, the chain may be removed for replacement. In order to use this feature, however, there are two bolts that secure the bar to the body that must be loosened prior to any adjustment and tightened bach up after making adjustments to the chain. The above will be enough to remove and replae the chain. If you are taking off the bar (that the chain runs on), you will need to remove the two bolts that were just loosened for the chain adjustment (above).
Regards! --WoobieDog--
SOURCE: I need replacement brushes for the electric motor
With a little work on your part (the correct model number) you can find an IPL here:
Remington.com
http://www.desaparts.com/index.htm
The 3 models I looked at for brush assemblies all said NLA. RemingtonPower is no longer producing anything. Replacement parts are limited to what is on hand and it appears have been exhausted. We are not affiliated with them in any way, and had nothing to do with their decision to end production. We like you are limited to an on line search for any parts.
If you decide to replace this I suggest you spend a bit more and purchase a name brand (McCulloch/Poulan, 8 electric models, some at Lowes). These companies are owned by Husqvarna and I expect all to continue providing great customer service for many years to come. HTH
Lou
SOURCE: Chain replacement.
loosen the one or two nuts that hold the bar tight and loosen the screw that you use to adjust the chain tension then remove the nut or nuts and the bar, then the chain. put it back in reverse order.
SOURCE: where can I find a chain saw blade for my
Oregon Bar & Chain Selector
http://www.oregonchain.com/pro/lookups/selguide.aspx?BusId=OCS&SellReg=USA&LangId=ENG
Your data gave me bar pn 540530 (solid nse 16" bar). There is a dealer locator on the lower right corner of the guide.
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Lou
Thank You for using FixYa.
