What does it mean when you dream you can fly?
Usually a sense of euphoria or freedom is felt when flying in dreams, perhaps signifying you have freed yourself of a sticky situation or have achieved a recent goal. Freud saw flying as representing
Could be not enough water or too much. Also could be white flies, which you will see or spider mites. Also might need fertilizer. If the bottom leave are turning yellow, then it is a nitrogen deficiency. If you have spider mites, wash the leaves with very mild soap and water and then rinse with plain water. They like to have a set watering schedule, ie: everyday/other day at the same time. Hope this helps.
Have you messed with the helicopter wire antenna at all? It's the plain wire that comes wrapped around one of the landing skids and should be left like that. Also, make sure the metal antenna on your remote is fully extended. Normal operating range is 50-100 meters maximum depending on surroundings and interference. Are any of these potentially the issue?
There may bad news on the repair from for this particular TV. Having worked on several large screen projection TVs, the prognoses is bleak.
This particular model uses 3 high output picture tubes (R,G,B) and each are triggered (shine) from the exact same "fly-back transformer". All the older picture tube style TVs have used this device as the sole means of generating the actual light that projects to your eye. When it goes bad, the whole TV shuts down and refuses to operate Since the early 80's anyway).
Can you get another fly-back...? Maybe, but not without an astronomical price tag attached to it. That's not even including having it installed (this ****** just plain isn't plug and play).
Then once all that is done there is this wonderfully expensive process of re-alligning your picture. See, once the new transformer has been put in the guns (R,G,B) have been 'pulsed' into different projection points. So your tehnician gets to stand on his head and nudge-fudge and cuss the picture back to a presentable state.
If there is a huge sentimental attachment to the TV then it might warrant the expense, but if I read this model correctly, you'll have to have a digital converter box or cable to get the proper picture anyway. Sadly, it may be time to look into another veiwing investment.
Sometimes it is a simple thing like a faulty bobbin, there is a very small piece of plastic that the winder has to catch and if it is worn or broken or just plain faulty then the bobbin will not turn
