Yes you can. To answer your question specifically, you would have to use the Onkyo for the input of your turntable. Then connect the line out or record out of the Onkyo, to any high level input on the Yamaha, such as DVD, CD, AUX. Kind of a waste of time and money, but yes, it can be done. If you need more information, or to inquire about a repair, please visit my website at audioserviceclinic.com. Thank you.
You can buy a magnetic cartridge pre-amp separately. Probably will be easier.
SOURCE: I tried connecting my old Technics turntable using
you turtable will need a pre amp especially if you have a magnetic pickup cartridge
SOURCE: Buzz coming from speakers on phono input
is the wire loose on either end? sometimes the electrical plugs can cause noise due to resistance, so trying different outlets might help too
SOURCE: Phono Preamp buzz
Ditto. Double check the ground cable. If it is connected, then try a different set of RCA cables. Also check the connections on your headshell/cartridge. Make sure all 4 wires are properly secure.
- OPTiC
DJ PRO LAB
DJ PRO AUDIO
SOURCE: I have a Technics turntable SLL20 and I am trying
Yes, signal from a turntable is much lower than that from tape/CD.
