Sony Playstation 3 (PS3) Console Logo
Posted on Jun 25, 2009
Powers up but will not play game or movies
Green and blue light on blank screen already checked cords and shut system down by holding down front power switch for 10 seconds what should i do
Anonymous
Level 1:
Problem Solver:
  • Contributor 6 Answers
  • Posted on Jun 25, 2009
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
6
Questions
0
Helped
694
Points
12
Here's what you do send it to Sony and wait a year to get it back that's if your still under warranty which is about a year or..........go to staples and ask for a DVD or blue ray disk cleaner to put into your ps3 system a blue ray cleaner would be better but a DVD cleaner could work. this is mostly caused by putting dirty disks into your ps3 system the blu ray laser is probley just dirty nothing to worry about
ps. have you tried out burnout paradise and midnight club LA they are awesome you should check them out and for some good reviews of ps3 and xbox 360 games you can go to rawgamplay.com
We were playing a game and the tv screen went black then we ejected the game and the wii console will not shut off and now it wont play a game or nothind then we tried to unhook it and the light stayed...
Power light is green or orange - TV screen is blank
    If the power light is green or orange and your screen remains blank, follow these steps.
    1. Completely power down your system by pressing the power button for 10 seconds. If that doesn't work, unplug the AC Adapter from the Wii for a moment, then plug it back in.
    2. Make sure your Wii console has the most current Wii system menu. Download the latest update (how to), and then test your Wii console to determine if the problem has been resolved.
    If you continue to experience this issue, there is a problem with the Wii console and it will need to be repaired.
DO YOU FIX PS3s... I have tryed everything i can think of incloding different cables HD & normal,different TVs HD & normal Also holding down the power button and waiting for the beeps.But nothing...
  1. Make sure the HDMI cable is connected to the HDMI OUT port on the back of the PLAYSTATION 3 system. Connect the other end of the HDMI cable into the HDMI Input port of the TV or display monitor.
  2. While the PLAYSTATION 3 system is in standby mode (red light on the front of the system), hold down the touch-sensitive power button on the front of the system until the system goes into standby mode again . (So the light cycle would go from: red light --> green light --> then back to red light). This will ensure that you have held down the power button long enough to reset the Video Output Settings.
  3. Turn on the PLAYSTATION 3 system and once the system finishes powering up, the Video Output Settings will automatically reset to the standard resolution (or detect the current display output settings of your TV/monitor).
SAFE MODE
Have a look at this, it may help.
1helpful
Ps3 won't work after pulling out the power cord
Plug it in and turn it on with the switch in the back. Hold the ON button in the front for about 10 seconds. Its gonna beep a few times
That should reset the play station. Game On.
My ps3 won't play discs
this has happen to me!! and i end up buying another ps3 and it end up the same!!! i fix both of them!!! and about over 200 consols with the same problem!!! this is what u do! you connect your control direct to your ps3. and then you hold the power button for 5 seconds!! the system will turn on!!!remove your finger for a second and hold the power button till you hear 2beeps then remove your finger and the system will shut off!! this is a manuel reset!!! the system will turn back on!! asking u to connect your controller!! you already have it connected. then it will give you about 6 options!! you will choose RESTORE FILES!!! your system will check for your system defaults!! then it will tell you that you have corrupted files!! and proceed with it!!! it will fix if you have problems with your controls,if it doesnt play games,blue ray,if it freeze, system shutting off,icon problems,only playing sertting games or movies!!! if you have problems or any question feel free to ask!! i know is fustrating!!!
2helpful
My PS3 plays blue ray movies,dvds,ps2 and ps 1 and no ps3 games
hold the power button down when it is red till you hear the quick beeps then select the file restore this is a diagnostics menu..remember you have to hold the power button down till you see a menu that youve probably never seen
2helpful
TV Blank when powering PS3
When tv and ps3 backswitch turned on hold down the front power button when off until the ps3 has done a double beep after the intitial beep and wait for a max of 1 min and initial set up screen should appear
1helpful
Plays films, won't play games
this is what u do! you connect your control direct to your ps3. and then you hold the power button for 5 seconds!! the system will turn on!!!remove your finger for a second and hold the power button till you hear 2beeps then remove your finger and the system will shut off!! this is a manuel reset!!! the system will turn back on!! asking u to connect your controller!! you already have it connected. then it will give you about 6 options!! you will choose RESTORE FILES!!! your system will check for your system defaults!! then it will tell you that you have corrupted files!! and proceed with it!!! it will fix if you have problems with your controls,if it doesnt play games,blue ray,if it freeze, system shutting off,icon problems,only playing sertting games or movies!!! if you have problems or any question feel free to ask!! i know is fustrating!!! i did some research and this is what another expert said to do
X box 360 console
Most of the time when you have 2 red flashing lights one of the clamps has come loose holding down the cooler on the GPU or CPU.
PS3 won't turn on
hi Torgsrus.
PS3 Light sequence
The following pictures illustrate the CECHX0X model, however the light sequence is applicable to all PlayStation 3 models.
No lights are on:
When no lights are on, this means that the main power switch on the back of the ps3 is off or the PS3 is unplugged. When the main power switch is off (the '0' is pressed) and you will not be able to access any features of the PS3 system. To turn on the PS3 system, make sure the main power switch is on (the 'I' side is pressed down).
If the PS3 does not turn on:
· Make sure the power cord is not frayed or damaged
· Try using another power cord, if available
· Make sure the main power switch on the back of the PS3 system is turned on
· If you continue to have issues contact our Technical support.
Solid Red:
When the power status light is solid red, this means that the PS3 system is off (or in standby mode).
Standby, mode means the PlayStation 3 system is off, but is ready to be turned on by pressing the power button.
If the ps3 system will not turn on when you press the power button, this is an issue with the PS3 system and you will need to send your system in for service.
Solid Green:
When the power status light is solid green, this means that the PS3 is turned on.
You should be able to navigate the XMB, play games, access the Playstation store,etc.
To turn of the PS3, simply press and hold the power button for two or more seconds.
If the power status light is green ,and you are experiencing problems- have a look on our forums for troubleshooting.
Flashing Red:
When the power status light flashes red after using the PS3 system for 3 or more minutes and shuts off, the PS3 system has possibly overheated.
This may be caused by poor ventilation or the vents may be blocked.
If this happens:
· Check to see if the vents are blocked. If the vents are dusty, vacuum the vents to remove the dust.
· If the PS3 system is in an enclosed area like an entertainment area, move it to a more open area.
· Leave the ps3 system off for 30 minutes to let it cool down.
· If you continue to have issue, you may need to send the console in for service.
Flashing Green:
When the power status light flashed green, it means that the PS3 system is turning off. Please wait while the system turns off.
If the PS3 system does not shut down immediately, it may be trying to finish save data to the Hard Drive. If it is, do not turn the main power switch on the back off as it may cause data on your hard drive to be corrupted.
If the green light continues to flash green, the ps3 system maybe trying to write to the hard drive, shutting down or running programs. It may take longer to shut down depending on when you pressed the power button. If the green power light flashed for a very long time, you can try holding the power button down for 5 seconds, the console will beep and should turn off. Then try to restart the PS3 system.
Flashing Green, Yellow and Red:
When the power status light goes from green, to yellow, to green, then to a flashing red, this means that they may be an issue with an internal part with in the PS3 system. This may be caused by a variety of reasons and would need to be diagnosed by our support line.
When the PS3 power light flashes in this order, you can contact our Support Line for further assistance.
Solid Blue:
When the disk status light is remaining a solid blue, it means the disc is inside the PS3 system. If you wish to eject the disc, hold down the eject button for 2 seconds and the blue disc status light will flash indicating the PS3 system is attempting to eject the disc . (NB: the power indicator light will always be a solid green).
If the disc is inserted into the ps3 system, but does not show up on the xmb or will not play, this may indicate an issue with the reader- check our guide Discs are not loading in my PlayStation 3? for further troubleshooting.
Flashing Blue:
When the disc status light is flashing blue, it means a disc was just inserted into the ps3 system or a disc is trying to eject from the ps3 system. Depending on when you pressed the eject button, it may take longer for the disc to eject. (NB: the power light will always be a solid green)
If the light constantly flashes blue, it may be an issue with the disk being stuck in the system. If this happens there is no way to remove the disc yourself if you are using an orginal 60GB PlayStation.
DVD-videos won't play, games do
If your PS2 is chipped for playing PS2 fake games then try the following steps: 1)Insert the DVD movie in your PS2 and hold the power button of PS2 until it light goes red. 2)Now again hold the power button until the light turns in green. and after that your DVD movie should work. ________________________________________________ If above solution does not works replace the lens with a new one.
Top Sony Video Game Consoles & Games Experts
Grand Canyon Tech
Grand Canyon Tech
Jose Ramirez
Alexander
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
