SOURCE: Printer prints all pages on one sheet of paper
what application are you printing from? also, can you do a print preview to see if there are more than one page? if that works, then your printer mechanism is not following the driver information from the print queue manager.
SOURCE: Printer prints partial page and then stops
We have had the same problem. I have found that if I close all windows not being used on the computer, then try to print the document again the entire document prints. This happens on an older computer we have that doesn't have alot of RAM.
SOURCE: Cannot install Canon PIXMA MP190 printer
Thank you for your promptitude.
Today I solved my problem. Was a cable connection problem. Cable incompatibilit or all 3 cables used before are damaged. Tuday I buy an other new cable and SUCCESS!!!: my computer see de printer ("new hardware found" when attach usb cable) , create virtual usb port, install the drivers (I have the drivers downloaded from the Canon web site) and printer is working fine.
Anyway, thank yow again for your support!
SOURCE: HP PSC 1610 All-in-One not printing anything including test page
try this.. i got the same problem before.. and the main problem is the NO MECH MODE.. try pressing the setup button then take the plug out of your printer.. (still pressing the setup button) and put the plug back.. and it will remove the no mech mode.. then you could print like before.. i hope this helps
SOURCE: MFC-490CW Won't print black
We are going to attempt to do a "power purge" to get rid of any clogged ink nozzles. Note, this will probably eat up about half of your ink, but that is the price you must pay in order to attempt to fix this bad boy.
1) Get into maintenance mode. Press these keys: Menu -> Black Start -> Scan x4 (hit it four times). A number pad should come up. If not, do it again.
2) Hit key 7, then key 6.
3) Press the right key until you get to "CLEANING BLACK."
4) Press 3.
5) Press Black Start.
After it purges and gets back to the main maintenance screen, press keys 9 and 9.
Let your printer start back up. If this does not work, try the above steps up to three times. If it does not work then, you need a new print head, which is not a user-replaceable part on this model.
Good luck.
This is generally how your format the hard disk and install
Windows.
First you need a Windows XP or Windows Vista installation CD and the product
installation code, which is printed on the Windows label on the bottom of your
laptop.
Boot up with the Windows installation CD start and follow the instructions to
install Windows.
Next Delete the existing Windows partition.
Next Create a new partition.
Next format this new partition - Format the partition in NTFS not a quick
format. This will prepare the Windows for a clean install.
Next create a User(name) and company name (normally Home is all you need).
Further into the installation, you will be required to put in the Installation
code.
During the final stages of installation you need to create
an User or Users that will use this computer.
When you finished installing Windows you need to install the
laptop's device drivers. You need to use a computer with Internet access to
download these drivers from the laptop manufacturer's WEB site and install
these drivers on your laptop.
Next connect a LAN cable to the LAN port from your computer to your DSL or
cable modem and you need to Activate the Windows installation on the Microsoft
WEB site.
Next up need to upgrade Windows from the Microsoft WEB site including Service
pack.
Next you need to install your programs
You can download the device drivers from Dell WEB site,
the support download page. Make sure you select your model desktop or laptop,
better still, type in the Service Tag number, it is printed on the label on the
bottom of the laptop and on the back or sides of a desktop. (If the Service Tag
label is missing then go into the BIOS setting and on one of the BIOS pages,
the Service Tag number will be displayed). This will open the page where the
specific drivers for your model computer are located. Also make sure you select
the Windows of the drivers for your Windows operating system. Click on this
link to download the drivers: -
http://support.dell.com/support/downloads/index.aspx?c=us&l=en&s=gen
To format the hard disk and re-install Windows use the Windows installation CD, and the Windows Product Code on the label at the bottom of
your laptop.
Boot up using the Windows installation CD and follow the
instructions.
One of the installation early steps, the option to delete the existing partition, then create a new partition and then a full format on this partition (don't do a quick format) and complete the Windows installation.
Next install all of the Toshiba's computer/laptop device
drives.
Next install the Windows service packs (SP2 & SP3 for
XP, SP1 & SP2 for Vista)
Next Activate Windows via the Internet or by phone.
Next install your programs - Microsoft Office etc.
Next
click on Start - Programs - Windows Update (for the latest updates).
