The Homelite ZR10580 uses a Champion RCJ4 spark plug:
Champion 893 Spark Plug
SOURCE: spark plug gap
hi kathy. this is an easy one. first of all you will need a spark plug gapping tool, about a dollar at any auto parts store. Your chain saw most likely calls for PLUG TYPE: Champion CJ6 SPARK PLUG GAP: 0.025 in. (0.63 mm).
Here is the website of a short video to show you exactly how to gap the spark plug. write back if you need any more info.
www.expertvillage.com/video/6078_spark-plugs-gap.htm
SOURCE: I just received a Recon unit of the Homelite model
it would be on the bottom of the saw or right behind the flywheel under the outside chain case
SOURCE: i need to know the
You need to mix 2.6 ounces of 2-cycle oil (NOT motor oil) with one gallon of fresh gas to get a 50 to 1 mixture. Most 2-cycle oil is sold in small bottles this size and have directions on them to get the correct mixture.
SOURCE: No spark on my homelite 150 automatic chain saw
remove the cover then the small wire from the coil crank it over if you get spark the wiring or switch is bad if still no spark the coil is bad
