Master
- Posted on Jun 01, 2014
Re: How do i do a hard reset on a magellen maestro 4040?
Slide the Magellan GPS unit's power switch to the off position, if your GPS has a two-way slide-style switch. Hold the switch in the off position for 8 seconds or more to reset the device.
Slide the switch to the reset position if your GPS has a three-way switch. These switches feature "Reset," "Off" and "On" labels. Hold the switch on the reset position for 10 seconds to initiate a reset.
Inspect your GPS for a reset pin hole if the unit has a push-down power button rather than a switch -- check the bottom and sides of the device for a pin-sized hole. Insert a pin or a straightened paperclip into the hole, pushing until you feel a slight pop. Hold the pin or clip down for 10 seconds and the GPS will reset.
Read more: http://www.ehow.com/how_5635240_reset-magellan-gps.html#ixzz33LpAdUJE
