SOURCE: Replacing the bump head on homelite string trimmer
undo the 2 screws on top of the carb. The bulb is part of a 2 piece cap undo that and it fall out.
SOURCE: Correct gas to oil ratio for Homelite Mighty String Trimmer Model
most trimmers are 50:1. or 40:1. i would use synthetic 2 cycle oil and use the 50:1 ratio. i know guys with trimmers that require 50:1, and they use synthetic at 80:1 with no problems for years. they say the engine runs cleaner. i am a part-time lawn care operator.
SOURCE: homelite st-175g trimmer
This is for a duel line trimmer. I hope this will help.
Cut two separate pieces of string, about 7 ft. each.
Stick the end of
the line in the hole on the inside of spool.
Wind clockwise onto spool,
putting the line that is closest to the ground on first.
Once you have
winded this piece on, lock the last 4 inches of line through the slits
on spool.
Repeat process for second piece of line, locking the last 4
inches in slot opposite the other locked in piece.
Put the spool on the
trimmer, feeding the end of lines through either hole on trimmer.
Before you push the spool all the way on, pull the strings out of the
locked position. Put cap on and GO CRAZY!
Jim
SOURCE: Installing new line on my string grass trimmer
Stick the end of
Once you have
on spool.
locked position.
Jim
SOURCE: Need parts for Ariens ST 622 string trimmer
MY ARIENS ST622 starts but then dies down quickly any ideas?
