Starts and then immediately stalls
Sounds like fuel starvation, but I have a hunch that may be a design flaw in the HT ignition system whereby only a poor spark is got on tick-over. Maybe slightly narrowing the plug gap may work. Otherwise
checkout this from other contributors:
To start the machine properly you must depress the primer bulb at least 3 times to start the engine. The primer bulb is on the side of the carburetor. It can be black or red. otherwise, the ports in your carburetor could be clogged. Locate your carburetor and find the aluminum bowl underneath. On the bottom of the bowl, you'll find a bolt. Loosen the bolt (gasoline will come out because the bowl is a reservoir for gas, but please make sure you've turned the gas supply off) and remove the bolt and the bowl. Clean any debris out of the bowl. The ports are holes in the bolt you removed. Make sure that air can pass through these holes ( use thin wire, carburettor cleaner, etc.) Reassemble and your machine may run ok.
