Tablets & eReaders Logo
Jim Farmer Posted on Oct 30, 2017
Wi-fi not obtaining IP address and if turn off wi-fi can not get to turn back on
If i turn off tablet and it when turn back on it goes to COBY flash screen and then android flash screen it comes up connected to wi fi but internet function not working it is disconnect and thry to reconnect to network it get in a obtaining IP address loop. If I turn off wi fi insettings it will not stay on just keeps going back to off.
5 Related Answers
dj_relly999
dj_relly999
  • 4070 Answers
  • Posted on Oct 31, 2010
SOURCE: I purchased the coby kyros internet tablet from
Hi! As a first course of action, I strongly suggest that you look via internet for the driver. Hope this helps and thank you for using FixYa!
Anonymous
  • Posted on Jan 04, 2011
SOURCE: my galaxy tablet cannot detect
Does the WiFi router have SSID? Did it ever connect to other WiFi Access Point before? If not some say to set the Tab on Static IP and configure the router to allow the Tab's MAC address. Hope it helps.
YaBaPortugal
Filipe Polido
  • 124 Answers
  • Posted on Mar 06, 2011
SOURCE: Cannot connect to the internet with my w-fi, I
Is there a DHCP server running? Like a router with DHCP enabled? How does your laptop connect? do you have a fixed IP address for the computers/laptops? What kind of encription are you using ? WPA ? WEP ? none ? Set a fixed IP within the same range and try again.
Kris
  • 73 Answers
  • Posted on Aug 29, 2011
SOURCE: have a samsung galaxy tablet
Have you tried holding the power button for 10+ seconds? or can you remove the battery?
Testimonial: "thanks tried holding power button longer but it workede thanks"
Anonymous
  • 10 Answers
  • Posted on Oct 26, 2011
SOURCE: my android tablet is "frozen". Will turn on but
has anything been deleted from it when it has been plugged into a computer or has anything been deleted from the device itself from its root directory? if not and its gone like that by itself, it could be corrupted software or a missing root file which is usually bad at first, now what i know about some tablets is if it wont work theres a recovery file usually internally but this is in some tablets only that ive read about, i also have one but havent needed to try to restore it and it can be done from an engineering mode, this is possable by pressing the power button and another button like the home button at the same time once the unit is off untill it turns back on with options, but as for some models im not sure of but i will have to look this up at some stage as i am working on tablets at this time so unless you know what you are doing i wouldnt attempt it, once i have gotten through some tablets ill be able to give a better resolution on this subject with others. the advice ive given wont work for all as pressing power and home will start different options up on different tablets and versions.
I have been using wi-fi printing on Samsung Galaxy 8.4 Tablet & now I'm unable to get my tablet to print.
Your printer may have changed it's IP address. This is a common occurrence on wireless networks. You should be able to get the new IP (to configure your tablet) by doing this on your printer: Go to the Home Screen --> Setup, then touch Reports and then select Network Configuration to see all of the printer's network details.
How do I get a new IP address for my next book android 4.0 tablet it is saying unavailable
Most Android devices have an IP address only when they have connected to a router, usually by wi-fi (other times it isn't needed).
When connected go to the Settings menu, tap Wi-fi, then tap the name of the network you are using. The device IP address should be listed .
1helpful
2answers
Ok I asked the question three days ago why can I get on a free wifi connection with my phone but not my tablet
The free Wi Fi router may have run out of IP leases on its DHCP server just when you were trying to connect the tablet. If the leases are as an example say one week long then if lots of people connect to the free wi fi they get a lease for one week. So if the device comes back within the week it already has an IP address assigned to it and works. If a new device comes along it has to ask the DHCP server via the WI FI to assign it an IP address. If all available IP addresses are leased from the WI FI router the device will not get assigned an ip address. Would suggest trying to connect the Tablet on another Wi FI system to test it works.
I had this happen on my mobile phone when I was in Surfers Paradise in a Coffee shop and suspected the lease time on the WI FI router was too long for the amount of short term customers using the coffee shop. (the staff had no idea on why the Wi FI was not working so it would have been pointless to try and explain this concept to them and how to change the lease time on the dhcp server) Also there is a limit to the simultaneous number of users on a Wi Fi frequency on one access point . Unless the WI FI uses multiple WI FI access points.
2helpful
5answers
How do I connect to wi-fi?
To start you need to check you are entering the right password! The password is the one for the WiFi! Is it written on a card or on the router, it will be case sensitive!
Assuming you're trying to connect via wireless router. If you connect, but then aren't able to get to the Internet. I would something is wrong between the router to the modem to the wall (DSL/Cable modem) rather then your tablet device. You can connect your device to your router and you device will show it has a wifi connection, but beyond the router something may be amiss. Try seeing what you get from another device like computer or laptop. That might get you closer to your actual issue,
1helpful
Mac address of Dell Streak
Steve,
Below are steps to get the mac address on your Dell Streak.
From the home screen:
  1. Tap the Menu key
  2. Tap 'Settings'
  3. Scroll down and tap 'About Device'
  4. Tap 'Status'
The MAC is listed under 'Wi-Fi MAC Address'
How to find the IP address on your Streak:
  1. Tap the Menu key
  2. Tap 'Settings'
  3. Tap 'Wireless Controls'
  4. Tap 'Wi-Fi Settings'
At the bottom, under 'Wi-Fi Networks', tap the connection you are connected to and the IP address will be displayed on the next screen
Thank You,
Dell-Jesse L
Dell Social Media and Communities
My coby/kyros is not picking up the internet with wi fi
Some devices need the Wi-Fi service turned on/enabled. Please check your devices settings to be sure that Wi-Fi is "On"!
Top Coby Tablets & eReaders Experts
ZJ Limited
ZJ Limited
ADMIN Andrew
ADMIN Andrew
Kolbrun...
Are you a Coby Tablet and eReader Expert? Answer questions, earn points and help others
