If i turn off tablet and it when turn back on it goes to COBY flash screen and then android flash screen it comes up connected to wi fi but internet function not working it is disconnect and thry to reconnect to network it get in a obtaining IP address loop. If I turn off wi fi insettings it will not stay on just keeps going back to off.
Assuming you're trying to connect via wireless router. If you connect, but then aren't able to get to the Internet. I would something is wrong between the router to the modem to the wall (DSL/Cable modem) rather then your tablet device. You can connect your device to your router and you device will show it has a wifi connection, but beyond the router something may be amiss. Try seeing what you get from another device like computer or laptop. That might get you closer to your actual issue,
SOURCE: I purchased the coby kyros internet tablet from
Hi! As a first course of action, I strongly suggest that you look via internet for the driver. Hope this helps and thank you for using FixYa!
SOURCE: my galaxy tablet cannot detect
Does the WiFi router have SSID? Did it ever connect to other WiFi Access Point before? If not some say to set the Tab on Static IP and configure the router to allow the Tab's MAC address. Hope it helps.
SOURCE: Cannot connect to the internet with my w-fi, I
Is there a DHCP server running? Like a router with DHCP enabled? How does your laptop connect? do you have a fixed IP address for the computers/laptops? What kind of encription are you using ? WPA ? WEP ? none ? Set a fixed IP within the same range and try again.
SOURCE: have a samsung galaxy tablet
Have you tried holding the power button for 10+ seconds? or can you remove the battery?
Testimonial: "thanks tried holding power button longer but it workede thanks"
SOURCE: my android tablet is "frozen". Will turn on but
has anything been deleted from it when it has been plugged into a computer or has anything been deleted from the device itself from its root directory? if not and its gone like that by itself, it could be corrupted software or a missing root file which is usually bad at first, now what i know about some tablets is if it wont work theres a recovery file usually internally but this is in some tablets only that ive read about, i also have one but havent needed to try to restore it and it can be done from an engineering mode, this is possable by pressing the power button and another button like the home button at the same time once the unit is off untill it turns back on with options, but as for some models im not sure of but i will have to look this up at some stage as i am working on tablets at this time so unless you know what you are doing i wouldnt attempt it, once i have gotten through some tablets ill be able to give a better resolution on this subject with others. the advice ive given wont work for all as pressing power and home will start different options up on different tablets and versions.
Thanks for all responces but wifi working fine have numerous device using it. This COBY stopped working after it ran out of power. Have tried running factory reset and when you turn it on it says it is connected but internet not working. If you turn off wifi and tri to turni it back on if stays on for a second then goes to off stuck in that cycle.
