For some reason the milk is not getting hot anymore while the machine still produces a nice froth overall it seems the only source of higher temps in my latte or cappuccino is from the espresso. Any ideas how to get the heat back into the milk??
Ummn - something in your Q. seems not right. The milk is not heated directly - its only heated by the steam as it passes by (and picks up) by the milk using a venturi effect - same as a spray bottle attached to a garden hose. You say you have froth - but you can only get that if you have steam... (it does not just blow air thru to create bubbles). So froth = steam & steam = heat... so milk must be hot.
Suggest you check manual for the 'heat' settings for your expresso as this may have been changed. While this is adjustable, the milk is not.
Also always heat your cups before using them - the silver cup 'holder' at the top does a reasonable job but boiling water does far better.
Cheers Mike
SOURCE: Describe your DeLonghi BAR 32 Espresso
many of them having DeLonghi BAR 32 Espresso is suffering from the same problem it cannot be solved it is this model's drawback
SOURCE: Hotter coffee
can also - press menu untill temp comes up - set to high.
(only low med and high)
SOURCE: I have a Delonghi Magnifica
I purchased a unit second hand for my wife's birthday today. It's only 4 months old, got it home, tested it, same problem... No froth!
I've read all the posts here and all were very helpful troubleshooting guides however they did not solve the issue.
Understanding how the frothing mechanism functions is half the battle in figuring out the solution. It's a simple vacuum type system. No doubt you've read about checking the orings. This is definately the first thing to check however if this is not the reason then consider the following.
The larger of the white tubes that has the red and black oring inserts deep into its port on the tap. Why? It pushes steam past the milk pipe directly into the chrome frothing tube which causes a vacuum essentially drawing milk up it's hose creating the froth. What you can't see without further investigation is that on the underside of the tube centered between the red and black orings is a small hole. This hole is responsible for drawing the milk upwards. If this is blocked, and it probably is then no milk and no froth. Use a really small screwdriver to carefully clean the white tube both from the front and the little hole underneath.
So in conclusion. Any air leak between the red and black orings will prevent the vacuum required to draw milk up the tube and alternatively any blockage of the milk channel will also obviously prevent the flow into the frothing mechanism. Hope this helps.
SOURCE: I have a Delonghi Prima
Where is it blowing steam from? If it is coming from the milk spout then it most likely that the milk jug is blocked somewhere. If it is coming from where the jug connects to the machine (coupling) then you might need to change the complete coupling (assuming you used the correct orings). The biggest cause of frothing problems with these machines is lack of cleaning of the milk jug. Soak the top in quality milk cleaner for at least an hour and rinse thoroughly. Also run cleaner through it regularly using the milk only function.
SOURCE: DeLonghi Perfecta ESAM5500 when trying to make a
Had this exact problem a few times on a cleaned well maintained milk jug top with an ESAM5500M. Delonghi 'repaired' it by sending a new milk jug frothing top.
It's caused by milk fat deposits, the frother part on the milk jug may look clean but deep inside it's not. I clean mine with pipe cleaners, detergent and hot water and still it wouldn't froth.
The problem re-occurs for me every 6 months or so. You could buy the milk fat remover solution to clean it. Personally I just boil the whole milk jug frother in detergent and the again in descaling solution, that's fixed this problem twice now, although I think it will eventually corrode the 'o' rings on the frother, still cheaper than buying a new frother part each time though.
If it still doesn't work after that, the only other reason for this problem I found mention of was caused by a broken rubber seal where the milk jug fits to the machine. It's most likely to be milk fat deposits inside the frother though.
Two O-Rings. A small Black one and a larger Orange one.
