2010 Volkswagen Jetta Logo
P
Peter Robertson Posted on May 31, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Fuse for the alarm system
Which fuse is for the alarm system
Nigel
Level 2:
Habit-Forming:
  • Expert 111 Answers
  • Posted on May 31, 2014
Nigel
Expert
Level 2:
Habit-Forming:
Answers
111
Questions
0
Helped
32015
Points
281
Here is the full list of fuses for you! and for the car.
Fuses on E-box, on left in Engine Compartment
Fuse 1 - Not assigned
Fuse 2 - 10/15A - Engine control unit
Fuse 3 - 5A - Radiator fan control unit
Fuse 4 - 5/10/15A - Lambda probe heater,
Lambda probe 1 heater after
catalytic converter
Fuse 5 - 10A, 20A - Lambda probe heater1,
catalytic converter,
Fuel system diagnostic pump,
Charge pressure control solenoid
valve,
Exhaust gas recirculation cooler
change-over valve,
Crankcase breather heater element,
Vacuum pump for brakes
Fuse 6 - 5A, 10A,15A - Fuel system diagnostic pump,
Throttle valve module,
Activated charcoal filter system
solenoid valve 1,
Continued coolant circulation pump,
Auxiliary air heater heating element
Fuse 7 - 20A, 5A - Ignition transformer,
Fuel pressure regulating valve,
Fuel metering valve
Fuse 8 - 10A - Throttle valve module,
solenoid valve 1
Fuse 9 - 5A - Automatic glow period control unit,
Electric fuel pump 2 relay,
Fuel pump relay
Fuse 10 - 5A - Speedometer sender,
Brake light switch
Fuse 11 - Not assigned
Fuse 12 - 5A - Coolant circulation pump
Fuse 13 - 5A - Water pump
Fuse 14 - 5A - Engine control unit
Fuse 15 - 30A - Voltage stabiliser
Fuse 16 - 30A - ABS control unit
Fuse 17 - 30A - Automatic gearbox control unit
Fuse 18 - 20A - Automatic gearbox control unit
Fuse 19 - 1A - Onboard supply control unit
Fuse 20 - 30A - Onboard supply control unit (AW0)
Automatic intermittent wash and
wipe relay (AW1)
Fuse 21 - 50A - Secondary air pump motor
Fuse 22 - Not assigned
Fuse 23 - 40A - ABS control unit
Fuse 24 - 50A - Trailer detector control unit
Fuse 25 - 50A - Terminal 15 voltage supply relay 2
Fuse 26 - 60A - Automatic glow period control unit
Fuse 27 - 60A - Radiator fan
Fuse 28 - 40A - Onboard supply control unit (AW1)
Fuse 29 - 40A - Onboard supply control unit (AW1)
Fuse 30 - 50A - Terminal 75 voltage supply relay 1
Fuse 31 - 30A - Amplifier
Fuse 32 - Not assigned
Fuse assignment - Interior Fuse Panel
Fuse 1 - Not used
Fuse 2 - 5A - Electronic steering column lock control module
Fuse 3 - 10A - Instrument cluster control module
Fuse 4 - Not used
Fuse 5 - Not used
Fuse 6 - 10A - Vehicle electrical system control module,
Interior ceiling lights,
Tail lights
Fuse 7 - 5A - Fog lamp relay,
Instrument panel and switch illumination dimmer switch,
License plate lamps,
Fuse 8 - 7.5A - Windshield and headlamp washer pump switch,
Windshield washer pump
Fuse 9 - 5A - Airbag control module
Fuse 10 - 10A - Right steering column switch
Fuse 11 - Not used
Fuse 12 - Not used
Fuse 13 - 5A - Automatic dimming interior rearview mirror,
Light recognition sensor,
Parking aid control module,
Air quality sensor,
High pressure sensor,
Climatronic control unit,
Tire pressure monitoring button,
Back-up lamp switch,
Left washer nozzle heater,
Right washer nozzle heater,
28-pin connector
Fuse 14 4- 10A - Left steering column switch,
ABS control module,
Light switch,
Airbag spiral spring/return spring with slip ring,
Fuel pump control module,
Data bus on board diagnostic interface
Fuse 15 - 10A - 16-pin connector (diagnostic connector),
Headlamp range control adjuster,
Auxiliary heater operation relay,
Mass airflow sensor,
Positive crankcase ventilation heating element,
Left front headlamp,
Left headlamp beam adjustment motor,
Right front headlamp,
Right headlamp beam adjustment motor,
Fuse 16 - 10A - Engine control module
Fuse 17 - Not used
Fuse 18 - 15A - Left front headlamp
Fuse 19 - 15A - Right front headlamp
Fuse 20 - 10A - Automatic transmission control module,
Selector lever sensor system control module,
Tiptronic switch,
Ignition/starter switch
Fuse 21 - Not used
Fuse 22 - 10A - Ignition/starter switch,
Converter box,
Alarm horn,
Interior monitoring sensor,
Alarm horn relay,
Dual tone horn relay
Fuse 23 - 10A - Vehicle electrical system control module,
Light switch,
Rain/light recognition sensor,
Compass magnetic field sensor,
Fuse 24 - 10A - Vehicle electrical system control module,
Access/start authorization control module
Fuse 25 - 15A - Automatic transmission control module,
Multifunction transmission range switch
Fuse 26 - 15A - Brake system vacuum pump
Fuse 27 - Not used
Fuse 28 - 40A - Auxiliary heater operation relay
Fuse 29 - 1A - Vehicle electrical system control module,
Fuse 30 - 20A - Cigarette lighter,
12 V socket,
12 V socket 2,
Blocking diode
Fuse 31 - 30A - Light switch
Fuse 32 - 20A - Light switch
Fuse 33 - 40A - Heater/heat output switch,
Fresh air blower relay,
A/C control module,
Fresh air blower switch
Fuse 34 - 15A - Left front headlamp,
Fuse 35 - 10A - Steering column electronics control module,
Instrument cluster control module,
Signal horn activation,
Fuse 36 - 25A - Vehicle electrical system control module
Fuse 37 - 15A - Left front headlamp DRL
Fuse 38 - 15A - Right front headlamp DRL
Fuse 39 - 15A - Low beam relay
Fuse 40 - 15A - Towing recognition control module
Fuse 41 - 15A - Towing recognition control module
Fuse 42 - 20A - Towing recognition control module
Fuse 43 - 30A - Front passenger door control module
Fuse 44 - A25 - Rear window defogger relay,
Fuse 45 - 30A - Driver door control module,
Fuse 46 - 30A - Left rear door control module,
Right rear door control module
Fuse 47 - 15A - Fuel pump control module,
Fuel pump relay,
Fuel primer relay
Fuse 48 - 20A - Vehicle electrical system control module,
Fuse 49 - 20A - Climatronic control unit,
A/C control module
Fuse 50 - 30A - Front seat heating control module
Fuse 51 - 30A - Power sunroof control module
Fuse 52 - 20A - Dual tone horn relay
Fuse 53 - 15A - Front seat heating control module
Fuse 54 - 15A - Fog lamp relay
Fuse 55 - 20A - Light switch,
Fuse 56 - Not used
Fuse 57 - 15A - Radio,
Radio/navigation display unit control module
Fuse 58 - 1A, 30A - Telephone transceiver
DC/AC converter with socket, 12V-230V
Fuse 59 - 30A - Amplifier
Fuse 60 - 30A - Auxiliary heater control module
Hope this helps
--N
1helpful
Which fuse disarms the theft alarm system on a 2003 Saab 9-3 convertable?
Taking out the alarm fuse will cause the engine to never start. Try locking and unlocking the driver's door with the key to see if it resets. If not then service the alarm system.
2answers
Where is the fuse to the alarm for a 2003 gmc yukon
2003 GMC Yukon Car Security Wiring Diagram
www.modifiedlife.com/2003-gmc-yukon-car-security-wiring-diagram/
Whether your an expert GMC Yukon car alarm installer, GMC Yukon ... GMC Yukon, a 2003 GMC Yukon car alarm wiring diagram can save yourself a lot of time. .... Alex, double check ALL your fuses and make sure ALL your fuses are good.
How to Disable a Car Alarm - YouTube
? 2:41
https://www.youtube.com/watch?v=EKbjYlK4g0E
May 13, 2009 - Uploaded by ehowauto
In order to disable a car alarm, an individual will have to locate the horn that was put in and disconnect it, or ...
GMC out alarm fuse Questions & Answers - Fixya
www.fixya.com/tags/out_alarm_fuse/browse/gmc
If you have an alarm installed remove the in line fuse from the alarm and see if that ...Multiple issues with my 2003 GMC Yukon XL and hope someone can offer .
1helpful
Unable to hear alarm being set and no sound when alarm goes off
Ground wire bad on alarm horn under hood. Fuse blown on line to horn under hood. Fuse blown to alarm system. Bad ground on alarm system.
How to disarm security system 2005 cts
Hello. Security systems (alarms) can cause problems when they become bad. The best thing to do is disconnect the fuse for the alarm. Look in the fuse panel of your car and see which one is for the security system (alarm). Then you can pull out the fuse and it will disarm the security system. Good Luck.
What name or acronyms would be for the fuse to the aftermarket security system?
Aftermarket alarm systems do not have there fuses in the cars fuse boxes, the fuses are located in line to alarm system.
You will need to look under the driver side of the dash and locate the alarm box, and then follow wires back a little, there you will see a few fuse holders containing the fuses for that alarm system good day
1helpful
Location on fuse chart listt that disconnects alarm system on 2000 VW beetle
Naturally the alarm has a red current wire , try locating alarm module and clipping either red or black wires .
2answers
My alarm system is not working how do I fix it
You may need to have the key reprogrammed, by the alarm installers.
1helpful
The battery went dead. When charging the battery
Disconnect the fuse for the alarm system or unplug horn relay system to change battery if you unplug fuse you will have to reset the alarm, be sure you know how to do this before disconnecting the fuse to the alarm system. Hope this helps.
Top Volkswagen Experts
ZJ Limited
ZJ Limited
Bradley
Bradley
Thomas Perkins
Thomas Perkins
Are you a Volkswagen Expert? Answer questions, earn points and help others
