I need a free unlock code for blackberry Q5 on virgin network so that i can use any sim
Hi free unlock code is not available for your mobile. So better you can go for paid unlocking service. I would suggest this site Unlocking4u.com here you can get the unlock code and unlock your mobile. To get the code you have to mentioned which country is locked now,network provider and imei number. Then they send unlock code through email.
Unlocking4u.com
SOURCE: samsung e-250 i need unlock code
Please follow the instructions carefully! Following are the 12-point instructions to unlock your Samsung E250 phone:
1. First do a CUSTOM RESET by tying in:
*2767*2878#
(Phone may display foreign language – don't worry! The last digits after the * will appear as - - - -; this is normal)
2. Turn off your phone
3. Take the battery and SIM out of the phone
4. Take a wrong network SIM (a SIM the phone does not currently accept) and insert it ONLY HALF way in, so when you turn on the phone it won't detect the SIM. Very important so the phone won't ask for network password and will show "Insert SIM" message.
The process of inserting only half of the SIM. I advice you to take care and do it with a soft approach as you might not have done this before.
5. 2. Now put the battery in carfully behind the protruding SIM card and switch the phone on. The phone must show "Insert SIM" message.
6. 3. Without turning off the phone, now push the SIM card all the way in, at this stage the phone must continue to display the "Insert SIM" message with the WRONG SIM inside.
7. Now make a FULL RESET by typing: *2767*3855#
9. Change the NCK password to 8 zeros by typing: *7465625*638*00000000*00000000#
8. The phone should reboot working with "wrong" SIM inside. (Do not turn off the phone)
10. Disable network lock by typing: #7465625*638*00000000#
12. Check this is done with *#7465625#
If your phone is not unlocked please retry the above ensuring all steps are followed to the letter, 9 out of 10 people who have problems have made a simple error and find that when they repeat all the steps it works.
SOURCE: need free unlocking code for
Well if you are tied to a particular network all you have to do is to unlock your phone to use it any other GSM network. You can get the unlock code through online. Give your IMEI number & get the unlock code for ur mobile .............You also get through online..........I will suggest the websiteUnlocking.comwhich is doing good service .....you can approach this website.
SOURCE: Unlock CDMA Blackberry phone for other networks
unlock your CDMA Blackberry eaisly with Imei Unlock code. first call your service provider ask your Mep Code. But it takes time to give your Mep Code. or other option is go online. there are thousand of sites available to provide Blackberry Unlocking Codes. Buy your unlock code from third party. i hope this information is help you :)Good Luck
SOURCE: I have a new Blackberry curve 8520 and this is my
Every BlackBerry has "Subsidy code" or "Sim lock code". To remove BlackBerry subsidy code or sim lock a special Blackberry IMEI Unlock Code is needed. By entering Blackberry Unlock Code on your BlackBerry you can use your Blackberry with any GSM and SIM card around the world. Blackberry Unlocking is simplest way to remove any or carrier restrictions from your Blackberry. Remote IMEI unlocking is the safest and fastest way to unlock a cell phone.
Get this Blackberry curve 8520 Imei Unlock Code .i hope this will help you :)
Good Luck.
