Frigidaire FAC124 wall/Window Air Conditioner Logo
A
Anonymous Posted on May 31, 2014
Why isn't it blowing cold air and is dry inside, no water to drain out?
  • Official Brand Answer 2,267 Answers
  • Posted on Jun 02, 2014
Frigidaire
Level 0:
Answers
2267
Questions
0
Helped
1289335
Points
2557
Good Afternoon Friend,
I understand that your Frigidaire air conditioner, model# FAC124, is not blowing cold air and there is no water draining out. First, try setting the temperature to a lower temperature. Secondly, make sure the compressor did not shut off by switching modes. Make sure it is on cool and wait approximately 3 minutes and listen for the compressor to restart. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your air conditioner status has changed successfully. Hope this is helpful.
-Best regards-
WP
1 Related Answer
Anonymous
  • 1654 Answers
  • Posted on May 29, 2011
SOURCE: Air conditioner isn't blowing cold!
You will need the condenser coils repaired before you can charge it. These come from the factory sealed and they should not ever need a charge unless you have a leak. The hissing sound is more likely air in the system being pumped by the comressor and it is coming out a hole in the coils.
My portable air conditioner is flashing a red light to drain the water out of it and I have but it is still flashing and it is not blowing cold air
unplug it and give it a chance to dry. possibly has an electronic sensor that is still wet though no water in pan.
Wall AC Unit blows cold air for a little bit then blows hot air. If I turn it off for a while, it will do the same thing.
When you mansion water in the pan, do you mean the indoor coil pan or the outdoor catch "pan"? I've seen some models have a drain plug that's on the bottom of the outdoor panel or underneath. And that plug should remain installed. It uses that water to cool the copper freon tube that curves along the bottom of the outdoor section. With plug removed it can overheat. Basically it does not drain onto the ground outside, it retains its water. And the air entering side of outdoor coil is clean? May sound like repetition(forgive me). The side you see clearly is the air leaving side. The dual shaft motor has a run capacitor that may be weakening. And the outdoor air that passes thru the outdoor coil may be recirculating out then directly back in to the unit causing it to overheat. Anything blocking airflow outside? 10 mins of runtime then shouting down tells me its overheating. It may even be the electrical circuit. Loose connections can cause high amperage, low voltage issue and cause the ac load to over amp. Over amp=over heat. Hope this helps!
I have a moretti elite portable air con and it's not blowing cold air it's second hand and a red light is on saying water full
Air conditioners remove humidity or water first, look for the bucket inside and drain it. or it is plugged and not draining.
1helpful
Water not heating up and not drying
Hello
If your dishwasher is not heating properly, troubleshoot the issue. You can often repair this problem and eliminate service fees.
Incoming Water
Most manufacturers recommend that the water coming into your dishwasher be at least 120 degrees Fahrenheit. If the water is too cold, then your dishes don't clean properly. Or the dishwasher must run longer to heat up the water. Test the water temperature by running the hot water on your faucet for about 2 minutes or until it gets really hot. Place a waterproof thermometer under the water. If the water is too cold, increase the water temperature setting on your water heater.
Thermostat
The thermostat is responsible for regulating the water and drying cycle temperature. If this thermostat isn't working, the heating element at the base of the dishwasher tub may not come on. Test this element by selecting the hottest temperature setting. Run the dishwasher on the shortest cycle. Let the dishwasher run for a few minutes, and open it up. If the dishwasher water is not hot or the drying cycle isn't starting, order a new thermostat from a parts dealer since this component is difficult to fix.
Heating Element/Drying Fan
The heating element heats up the water and air. Access this element by removing the bottom rack. It looks like a long black rod. If any part of this component is broken or corroded, you must order a new one. You usually cannot fix this element. The drying fan is located in the main housing of the dishwasher, and it blows air around your dishes to dry them. Check this part by disconnecting the dishwasher from the power supply and opening up the housing. Examine the fan, and see if any dirt or debris is preventing it from moving. Clean it. If the fan won't turn at all or if the motor is burnt out, order a new fan since it's difficult to repair this part.
Additional Concerns
If your dishwasher isn't drying your dishes properly, see if you have selected a heated drying cycle. An air drying cycle doesn't completely dry your dishes. Never overload the dishwasher, as this prevents heat from circulating around your dishes, keeping them from drying properly. Plastic and Teflon dishes don't usually completely dry. You must towel-dry these items.
1helpful
Dishwasher not heating water already replaced in line heater element no change
Hello
Possible causes;
Incoming Water; Most manufacturers recommend that the water coming into your dishwasher be at least 120 degrees Fahrenheit. If the water is too cold, then your dishes don't clean properly. Or the dishwasher must run longer to heat up the water. Test the water temperature by running the hot water on your faucet for about 2 minutes or until it gets really hot. Place a waterproof thermometer under the water. If the water is too cold, increase the water temperature setting on your water heater.
Thermostat;The thermostat is responsible for regulating the water and drying cycle temperature. If this thermostat isn't working, the heating element at the base of the dishwasher tub may not come on. Test this element by selecting the hottest temperature setting. Run the dishwasher on the shortest cycle. Let the dishwasher run for a few minutes, and open it up. If the dishwasher water is not hot or the drying cycle isn't starting, order a new thermostat from a parts dealer since this component is difficult to fix.
Heating Element/Drying Fan; The heating element heats up the water and air. Access this element by removing the bottom rack. It looks like a long black rod. If any part of this component is broken or corroded, you must order a new one. You usually cannot fix this element. The drying fan is located in the main housing of the dishwasher, and it blows air around your dishes to dry them. Check this part by disconnecting the dishwasher from the power supply and opening up the housing. Examine the fan, and see if any dirt or debris is preventing it from moving. Clean it. If the fan won't turn at all or if the motor is burnt out, order a new fan since it's difficult to repair this part.
I have the refrig where the freezer is on the bottom, the bottom is working fine but the top is not getting cool.
a common problem with bottom mount freezers is the door gets left open,open the freezer door and look at the ceiling,is there ice on it and is there also frozen water droplets on the packages,if so the door was left open,you can shut the fridge down or unplug it,remove the food from the freezer,get a hair dryer and blow the hot air onto the back inside wall of the freezer mostly blow it into the open slots in the back wall,it will melt the ice that's in the air ducts,you'll see water dripping down,when it stops you can start the fridge and stick your hand in the top middle of the fridge section to feel if cold air is blowing in,all that it does is there's a fan in the freezer,all it does is blow the cold air from the freezer into the fridge section,if the door was open the warm air gets in and mixes with the cold air and it freezes up the air ducts and blocking them.if this isn't the problem open the freezer door,you should hear the fan blowing,if not you could have a bad fan motor,also put your hand on the back inside wall of the freezer,if there's like frost or snow on the back wall you have a defrost problem,a bad defrost heater,defrost thermostat or timer or board depending what the model is,but most of the time the problem is behind the freezer inside wall,or depending on your model there could be a damper in the fridge section,if it's stuck closed then the cold air won't blow into the fridge section.so first open the freezer door,listen for the fan,if it's blowing,check for frozen water droplets and ice up on the ceiling near the light and on the food packages,if you see this the door was left open,if the fan isn't blowing most likely it could be bad,then check the back inside wall for frost or snow on it,if there's frost on the back wall you have a defrost problem,most likely it will be a bad defrost thermostat or heater,you'll need to check them with a maeter,hope this helps,next time send the model number so i can look up your machine.
2helpful
Fridge is warm, was collecting water inside. Freezer is working fine. Increased temp but not responding. It is a bottom freezer model
send the model number off of the fridge,if the freezer is working fine then no air is being blown up to the fridge section,all it does is blow cold air from the freezer to the fridge section so either the door was left open and this is very common with a bottom mount freezer or the evap fan isn't blowing or on some models there's a damper inside the fridge section,the damper door opens and closes to let cold air in,when it reaches temp. the door closes,sometimes the door gets stuck in the closed position or the open position and the fridge freezes or gets warm depending on where the door is.first thing open the freezer door,do you hear the fan blowing,if not you could have a bad evap. fan motor,next look at the ceiling and on the packages,do you see frozen water droplets,if so the door was left open and the air ducts are froze up from the warm air getting in from the door being open and mixing with the cold air freezes up the air ducts,also stick your hand onto the back inside wall of the freezer,if there's like snow or frost on the inside back wall of the freezer you could have a defrost problem,bad defrost thermostat,heater,timer or board depending on the model or last a bad damper,when you open the fridge door there are air ducts usually up top and in the middle you should feel cold air blowing in,this is your problem the air isn't making it into the fridge section.if the door was left open,unplug the fridge,remove the food from the freezer and with a hair dryer heat up the back inside wall of the freezer and blow the hot air into the air vent holes in the back wall to melt out the air ducts,keep heating it up until you don't see any more water dripping,you can see the water dripping through the vent holes.so let me know what you find,send the model number and we can go from there.look up near the ceiling in the fridge section on the right hand wall and you should see a tag with the model and serial numbers,send the full model number so i can see what you have in your machine.
The freezer works well but the fridgedoes not get cold enough
all the fridge does is blow cold air from the freezer down into the fridge section so if the freezer is working then either the evap fan isn't working or the air ducts are frozen up.first thing open the freezer door,you should hear the fan blowing,if not the fan motor could be bad,if it is blowing,touch the back inside wall of the freezer,is there any ice or like snow on it,if so you have a defrost problem,one more thing to check,open the fridge door,look under the bottom draws,is there any water there? or any water dripping into the fridge section from the freezer,if so you have a blocked drain and the air ducts are frozen.let me know what you find,send the model number off of the fridge,open the fridge door and look on the left side up near the ceiling,you should see a tag with the model and serial numbers just send the model
Driping water inside house, blocked pipe? Mike
Take a wet/dry shop vac and find the drain line. Pull a vacuum on the drain line to dislodge any blockage. Worst case, blow into the pipe but cover everything inside because it will get wet!
2answers
I have an older Coldspot 1068627360 that stopped blowing cold in both the top freezer and bottom fridge areas. The motor is running the lights are on - just no cold. I recently moved the unit but it was...
Sounds like motor is running. Can you hear the fan blowing which is between fridge and freezer. It blows cold air to the venting between fridge and feezer. If the air is blowing but not cold, then you will probably need a recharge. If not running or no air is blowing, then the circuit board, fan, or tempsensor is likely bad.
Top Frigidaire Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Mike Cairns
Mike Cairns
Are you a Frigidaire Heating and Cooling Expert? Answer questions, earn points and help others
