Question about Jet 3 Ultra Power Chair
How do I change batteries in Jet 3 powerchair?
2 Suggested Answers
SOURCE:
bill91074
  • 401 Answers
SOURCE: why wont my jet 1 powerchair move with fully charged batterys
If the charger is unplugged and the freewheel levers are in drive position. The joystick should not have any flash lights on it, this indicates a flash code that needs to be addressed. If the lights are rippling up and down it could be locked out. some joysticks can be reset by pushing the horn button twice after turning it on within 10 sec.some are reset by pushing joystick forward until it beeps then back til it beeps this done right after startup also. otherwise there maybe something more serious going on with the chair. Strege Mobility
I’m happy to assist further over the phone at https://www.6ya.com/expert/bill_bcbb89783b08c489
Posted on Oct 10, 2017
Jet 3 Ultra powerchair. Why does it turn in circle only, if and when it wants to at least do that?
the freewheel lever is not in the drive position on both sides
Feb 12, 2016 | Jet Health & Beauty
Tip
Powerchair flash codes (Applies to most powerchairs)
The listed Flash codes are pretty standard and are applicable to powerchairs only not scooters:
1 flash User Fault (do not touch joystick) and turn back on
2 flashes Battery Fault Recharge batteries or replace
3 Left motor fault check connections or replace
4 Right motor fault check connections or replace
5 Left park brake fault check freewheel lever or brake connections
6 Right park brake fault check freewheel lever or brake connections
7 Remote fault check connections and wiring replace remote
8 Controller fault Check connections and wiring replace controller
9 Communication fault check cable replace
10 and 11 are unusual and will not be seen if at all
on Mar 06, 2011 | Health & Beauty
Powerchair motor wiring for jet 3
hi John, it;s rather straightforward , two wires for the motor two for the brake..
Motor wires are coloured black and red ...
Regards
Rob.
Feb 05, 2016 | Pride Mobility JET ULTRA 3 BLUE POWERCHAIR
New batteries new battery harness still 3 red bars and two yellow bars flashing what else could it be
[PDF]Pride Jet 2 Hd Owner's Manual - Scootaround
www.scootaround.com/.../manuals/pridemobility/Pride%20Jet%202%20...
The symbols below are used throughout this owner's manual and on the power chair to identify ... Jet 2 HD www.pridemobility.com. 3. TABLE OF CONTENTS.
Sep 28, 2015 | Jet 2 HD for 350 lbs, Power Chair,...
I want to donate a jazzy jet powerchair. its in good worling condition, just need new batteries.
The batteries range from 160- 500 bucks, look in paperwork for correct size and call around for best prices
Aug 14, 2015 | Jet 3 Ultra Power Chair
New batteries installed, and flashing red lights, continuous, will not move
hi , how many flashing red lights are all of them flashing ?
Regards
Rob
www.gewizrepairs.co.uk
Jul 22, 2015 | Pride Mobility JET ULTRA 3 BLUE POWERCHAIR
My Jet 3 powerchair stops and will then start again.
sounds like you have a loose connection somewhere. it takes experience and patience to find it call 1-800-800-8586 to seek a qualified tech in your area
Nov 11, 2012 | Jet 3 Ultra Power Chair
I cant get my power chair jet 3 to charge batteries are good
Hi valentin 201
I have owned my own business for 3 years and have been working on scooters and powerchairs for 15 years. . In the future give as much info about the scooter as possible.
1. load test the batteries even if you think they are good, check anyway. Sometimes even new batteries won't hold a charge.
2. Your charger on the powerchair must have enough volts to open the charger inhibitor. That is, the charger won't even start up if your batteries are low. Both batteries need to have at least 20-22 vdc.
3. Some chargers have a 3amp fuse check that and repace if needed.
4. With a multi meter set on dc200 check your batteries. Red on one battery and black on the other. Check to see what you get for voltage. If no voltage reverse the lead wire to the other posts. Once you get a reading of 20+ volts watch the meter and plug in the charger, it should increase the volts on the meter. if not the charger is bad, replace. Charger should be 24-31 volts to be a good charger.)
One of these sugestions will fix the problem
Good Luck
Tim
May 03, 2011 | Jet 3 Ultra Power Chair
WHAT MAKES THE CHAIR NOT MOVE WHEN CHARGING?
You cannot make a powerchair operate while it is charging. For safety purposes the power cuts out when charging batts. The only power is going to the batteries.
Feb 26, 2009 | Jet 3 Ultra Power Chair
Jet 3 Ultra Power Chair Logo
108 people viewed this question
Top Jet Health & Beauty Experts
Marvin
Marvin
Vincent G
Vincent G
ray gallant
ray gallant
Are you a Jet Health and Beauty Expert? Answer questions, earn points and help others
