Philips Magnavox MWD7006 DVD Player Logo
A
Anonymous Posted on May 30, 2014
What is the uverse code for a sony dvp-sr2vp?
BigO
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on Jun 06, 2014
BigO
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
6065
Points
Have you gone on the menu settings in your U-verse cable box. Under the menu settings in the the cable box go left all the way over to options. Under options there is a remote control set up. There they will give you some sets of codes to try for your product.
Model DVP-SR760HP. How can it be made region free?
Sony DVP-SR760HP region code - VideoHelp
https://www.videohelp.com > dvdhacks > sony-dvp-sr7...
Post Region code hack posted by ravikalyan_143, September 07 2016: 1. Make sure the DVD player has no disc in it and is powered off 2. Press 12345 on the ...
Sony DVD Player DVP-SR760HP - Uncoding of Region ...
https://forum.videohelp.com > Video > Authoring (DVD)
Dec 10, 2014 - Need help to make my new Sony DVD Player DVP-SR760HP Region Free. My player is suitable for Region 5. I have DVDs of Region 2 since I ... Sony DVP-SR760H Region free unlocking - VideoHelp Forum
Dec. 21, 2014
Need Help to make my Sony DVP-SR310P DVD Player region ...
Mar. 13, 2017
Sony DVP-SR370 DVD-player region code - VideoHelp Forum
Dec. 26, 2014
Region Code free for sony dvp-sr320 - VideoHelp Forum
Feb. 14, 2014
More results from forum.videohelp.com
Att Uverse remote set up code for Sony Dvd player
Google for it by model numbers but I doubt you will find one that works.
1helpful
Uverse remote s-10-s1 codes for sony str-dh520
For Sony STR-DH520 the AT&T Uverse code is 5151.
2helpful
2answers
How do I unlock my Sony DVP - NS330 player, bought
Codes for-
Sony DVP-NS300, Sony DVP-NS305, Sony DVP-NS400D, Sony DVP-NS700, Sony DVP-S330, Sony DVP-S335, Sony DVP-S360, Sony DVP-S336, Sony DVP-S525D, Sony DVP-S530D, Sony DVP-S535D, Sony DVP-S536D, Sony DVP-S725D, Sony DVP-S735D
Turn on the unit with the remote controller, Wait until "no disc" appears in the unit's display. Press the keys: PAUSE, 3, 1, 4, 1, 5, 9. And "CODE" will appear in the display. Press the number key that corresponds to the disc zone you want to play within the next 5 seconds:0: All regions / 1: Region#1 / 2: R#2/... and so on. Then, within 5 seconds, press: PAUSE, POWER... and voilà. If you don't have good results, disconnect the equipment and repeat.
Or
Put your player in standby mode and then enter: [[0] [ENTER] Default Default region code [1] [ENTER] or [UP] [ENTER] Region 1 [2] [ENTER] or [RIGHT] [ENTER] Region 2 [3] [ENTER] or [DOWN] [ENTER] Region 3 [4] [ENTER] or [LEFT] [ENTER] Region 4 [5] [ENTER] or [TITLE] [ENTER] Region 5 [6] [ENTER] or [DVDMENU] [ENTER] Region 6 [7] [ENTER] or [RETURN] [ENTER] Region 7 [8] [ENTER] or [DISPLAY] [ENTER] Region 8
Or
Put player into standby modes by pressing power button on remote control. Then press Title button. Press Clear button. Press Power button.
Yours is not listed but these may be worth a go.
or try http://www.haldigital.com/hp/dvd.htm
15helpful
2answers
47helpful
2answers
Need unlock code.
I found this region hack here Sony DVP-NS575P region code , check it out:
"Warning
The following guide describes how I managed to make my Sony DVP-NS705V DVD player multi-region.
There are no guarantees that you will be able to do the same. Be aware that you will probably void any warranty you have and possibly even break the player.
Put shortly, you proceed at your own risk.
Introduction
First of all, the Sony DVP-NS705V can be made multi-region simply by applying appropriate service codes, you do not need to install a so called "mod chip".
This supposedly applies to the entire NS-series of Sony DVD players. There are some encouraging reports out there supporting this, but nothing has been verified by me. Again, if you choose to apply this guide to any DVD player, you do so at your own risk.
If you do find that this procedure works on another model, please drop me a line at [email protected] and let me know. Include the exact model number and original region of your player.
Update: Some users have reported success on the following players:
DVP-F21 (special thanks to Garry Self for this one)
DVP-LS500
DVP-LS755
DVP-LS785
DVP-NC615
DVP-NS300
DVP-NS305
DVP-NS310
DVP-NS315
DVP-NS330
DVP-NS333
DVP-NS355
DVP-NS360
DVP-NS400
DVP-NS405
DVP-NS410
DVP-NS430
DVP-NS433
DVP-NS575
DVP-NS585
DVP-NS590
DVP-NS700
DVP-NS730
DVP-NS765
DVP-NS900
DVP-NS905
DVP-NS930
DVP-PQ1 (thanks go to Michael Joy for this one)
DVP-PQ2
RDR-GX3 (thanks to Andreas Norman)
RDR-GX7 (thanks to Daniel Tapie)
RDR-GX300
RDR-GX700
RDR-HX900
RDR-HX1000
Please note that not all players behave exactly like the NS705. For example, some players do not display "success" when hacked.
Thanks to all who have contributed.
The infrared service codes required to make the update are available on the Internet. Unfortunately, not many people have an appropriate device to enter the codes into. You basically need a programmable remote (Philips Pronto, One-For-All) or a PDA (Palm, iPAQ) with suitable software.
This guide shows you how to make the update with a regular PC equipped with an IRDA port.
The procedure
1. Download the winsamp -package from Blank Frank's site.
http://www.veg.nildram.co.uk/remote.htm
This innovative piece of software allows you to send standard home electronics IR signals using a PC IRDA port.
2. Extract the package onto a bootable DOS floppy disk.
3. Download this IR code
http://www.selen.org/files/REMOTE.TXT
file and place it in the same directory as the package above.
This file holds the five necessary IR codes converted to the format used by Blank Frank's winsamp.exe. Please do not bother Frank with questions concerning this particular procedure.
4. Boot up your PC from the floppy disk and run winsamp.exe.
If your IRDA port doesn't appear as COM2 you may override this by using an appropriate command line switch. For example, use COM1 by running 'winsamp C1'.
5. Press the 'r' key to load up the codes into winsamp.
6. Make sure your DVD player is in standby mode and your IRDA port is within range.
7. Run the IR codes from 1 to 5 by pressing Enter on each corresponding button.
8. Your DVD player should start up and display the text "SUCCESS".
9. Repeat step 7. Your player should return to standby mode.
10.Your player is now multi-region."
Top Philips Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
