Question about LawMate PV-1000 Law Enforcement Grade Pocket DVR
I have problem with my DVR PV-1000
I could not power up my PV-1000 dvr as it connected to computer and charging. I checked the HOLD button which switched fully to the left, What can i do?
  • Simge
    Simge May 31, 2014
    Please help me=((
  • Simge
    Simge May 31, 2014
    i could not power it up while it was charging. Now red light turn off but it is not working
My DVR stays in the sleep mode how do I reset
Can you give us a clue about what manufacturer and what model and what your DVR is connected to?
For example a certain DVR requires that you unplug the AC plug from the wall outlet, then hold down the POWER and MENU buttons, and then re-insert the AC plug.
That is one type of DVR.
Aug 23, 2018 | The Computers & Internet
Gamut cctv recorder admin password
To reset password of your CCTV DVR press and hold the ENTER button for 15 to 30 second until the DVR restart's. After the restart you DVR default wizard will come up the same way like if you are setting up the DVR for the first time.
Apr 04, 2017 | Computers & Internet
How do u program a phillips universal remote to a panosonic fm radio model # pv-c1320
Philips Universal Remote control Instructions
  1. Turn on the device (TV, DVR, etc.) you wish to operate.
  2. Press and hold the SETUP button until the red light indicator remains lit, then release the SETUP button.
  3. Press and release the desired mode button (TV, DVR, etc.).
More items...
Philips Universal Remote control codes for TV, VCR, Set-top Box ...
www.directutor.com/.../philips-sru210327-universal-remote-control-codes-tv-vcr-set-top... How to setup phillips universal remote to panasonic tv Google Search ..not sure if it will help you out but have a look.
Nov 29, 2016 | Universal Televison & Video
I can't find my DVR's password
you may have to check your user manual they may have a default pass word code.
Jun 12, 2014 | LawMate PV-1000 Law Enforcement Grade...
I have trouble with my PV-1000 DVR
Things to consider.
If using a VOIP system (via router) please consult your provider for the port(s) you should have open.
Some features are enabled on the system management page.
If you are using a tradition phone line, first consult your manual then your provider.
Hope this helps
May 30, 2014 | Evo Pv-500eco-pv-1000 Dv
I have a JVC tv with a Comcast DVR. Remote provided will not work on DVR.
did you take a look at the manual you should have recvd for your comcast remote control, You need to program your DVR, look in the manual for the 4 digit code and follow the instructions- usually- hold the dvr button on the remote down until it stops blinking- enter the code- (depending on who the manufact is) wait for the button to start then stop blinking, see if that helps
Feb 07, 2012 | JVC Televison & Video
Trying to connect to directv dvr for ON Demand services via ethernet cable, but directv dvr doesn't recognize connection
Run your DVRs outomated network setup.. If this fails, you will have to get the ip settings manually. to find them, use a computer that is connected to the router.. Do start, run, type cmd, press enter. In the black window that comes up type ipconfig /all this will give you the settings the DVR wants. choose manual setup from your DVRs network connection menu.
Sep 29, 2010 | 2wire (1000-400108-001) Router
Remote Code for Comcast DVR
See http://www.comcast.com/corporate/customers/customer_support/remotes.html
You will most likely have to use a VCR code and program it to the AUX button.
Feb 26, 2010 | Panasonic PV-C2541 25 in. TV/VCR Combo
Samsung DVR Combo no work
There is a small hole next to the power input socket. You are supposed to power down, hold the button in and power up, then hit the button again and hold until the menu screen comes up. Mine does not work, but that is about what it sayw in the manual.
Jan 25, 2008 | Samsung SSC DVR Digital Video Recorder...
LawMate PV-1000 Law Enforcement Grade Pocket DVR Logo
44 people viewed this question
Top LawMate Video Cameras Experts
Marvin
Marvin
Are you a LawMate Video Camera Expert? Answer questions, earn points and help others
