Just require wiring diagram for this wall mount airconditioner model number EWH09HRA thankyou
For the window type A/C, the wiring diagram should be stuck to the side of the control box (box with the control boards in it) inside the unit. The control box will have to be removed (after power isolation of course) to see it.
Good Morning Friend,
I understand that you are looking for the wiring diagram for your Kelvinator air conditioner, model# EWH09HRA. Typically, the wiring diagrams are not readily available. I suggest contacting the manufacturer, and have your model number available for them. They might be able to locate a copy of the wiring diagram of your air conditioner for you. Hope this is helpful.
-Best Regards-
WP
SOURCE: Fujitsu wall mounted air conditioner leaks into the room
Make sure the unit is level, this is very important. Check for blocked drain tube, which runs from the bottom of the drain pan under the cold coil to the outside. Clear tube with a piece of coathanger wire, be gentle.
SOURCE: Through the wall vs. window installation
I just purchased an alleged "window mount" air conditioner with the closest dimensions to the existing model. Do these mount as through the wall as well? My current opening = 18 x 26" the new purchase is 16 27/32 x 26.
There are 2 different types of window air conditioners – there are the window type of which will fit in a window that opens top to bottom and there is the slide in model of which the actual air conditioner will slide into a metal sleeve which is very common in apartments. In either case you need to measure the inside of the metal sleeve and then give that to the air conditioner dealer and he will know what to do and there is also a POS (point of sale) @ the store of which will also assist you in the measurement of the A/C unit – the window unit you need to measure the opening of the window itself, I hope this was helpful
SOURCE: KELVINATOR AIR CONDITIONER
whats the furnace doing exactly is the filter clean ? does the blower come on if you just put fan on ? do you have pwer to the unit ?
window mount doesn't have to extend out on the back to clear the side /top intake vents because a window is about 2" thick,
but a wall mount has to have about 6 to 8 " clearing before the intakes vents can be exposed. you can't have your intakes buried in the wall.
in short if you see about 8 " of dead metal in the center area (just behind the window sill) then you can mount it in a wall as it will protrude far enough to clear the side /top intakes.
a sleeve just gives you a way to balance / attach to the outside wall
SOURCE: Fujitsu wall mounted air conditioner.
during Cooling and Dry modes, if the unit is used under conditions of
lower temperature (18C) the heat-exchanger may freeze, leading to water leakage and other damage.
If the unit is used for long periods under high-humidity conditions, condensation may form on the surface of the indoor
unit, and drip onto the floor or other objects underneath. (About 80% or more)
Increase Temp to 20 and also run coil dry cycle,
