Nu-Flamehttps://www.nu-flame.co.uk
Home page for Nu-Flame Gas Fires UK, British Innovation, British Design and British Made including High Efficiency Gas Fires, Glass Fronted and Open Fronted ...
I know nothing about Enigma but this is typical of PC problems with memory. If there is a Keyboard, try getting into Bios by restarting and pressing F2 and Del keys alternately on turn on. This gets you into most computer Bios. When there, look for Memory/RAM to see if it is seeing any. Try "Reset to defaults" as a last resort.
Try to get the manual and look for "Trouble Shooting" section. If it has info on memory installation (for example, adding or replacing, read carefully.
If you have a techie guy there, think about opening up the Enigma to get to the main board (mother board) and removing the RAM module(s). If you can have them tested, do so. If not, clean them with a dry clean toothbrush, blow out(or vac) the main board socket the RAM came out of (be sure Enigma is plugged in and off and not too much vacuuming as it builds up static). And if there are more than one RAM, plug in only 1 or reverse the slots or use other slots if there are any. Try all combinations. Power off between each removal/insertion. Be careful and gentile but firm. Be careful of static electricity. Any little "Snap" you hear from touching some thing is a hazard to electronics, so keep in touch with the machine to stay grounded. Hold the RAM, use that hand to touch the Enigma 1st without touching the RAM to the Enigma and then proceed. That grounds you and by default, the RAM safely. Peep the Enigma plugged in but turned off except when testing.
www.heatnglo.com/Owner-Resources/Install-and-Owners-Manuals.aspx Each fireplace, stove and insert has a rating plate which contains your model number and serial number. Gas and wood burning fireplaces have a rating plate in ...
? 2:21
www.youtube.com/watch?v=_-8dY8tUGhw
Aug 24, 2012 - Uploaded by HeatandGlo
Resetting Your Heat & Glo® IntelliFire™ Plus Ignition System Video ... Relighting Your Heat & Glo® Standing Pilot FireplaceVideo - Duration: ... How to Install Your New Gas Log Set - The Fire Place - Palm Desert - Duration: ..
Here's a link for a driver. Just need to put in a verification code and then click download. Might have to click on a thing with a blue arrow pointing down that pops up on the top of the screen that asks you to download the file. If that happens you might have to restart the download.
I can almost definitely supply the installation instructions for you, however I need to know the model of the stove as the serial number doesn't actually identify it to anyone other than the manufacturer.
Some manuals with installation instructions can be downloaded by visiting the following page:
If your manual is not in the list, please post back with your model (this is usually a name, e.g. Exminster or Devon Double) and I will obtain the installation instructions for you if they are available.
yes go to ths link, took me ages to find but when i put in hte serial number it can straight up, but can you tell me where to buy the replacement coals? heres your link:
http://www.rinnaisales.co.nz/tradesmart/rinnai2/pdfs/installations/190.pdf
