Computers & Internet Logo
K
KittyAnn Posted on May 30, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Why do my icons don't appear in the lower right, I would like to reinstall day date calander and time
I had these before and I think that someone in my family deleted them. I would greatly appreciate any help.
Big Steve
Level 3:
  • Lenovo Master 1,087 Answers
  • Posted on May 30, 2014
Big Steve
Lenovo Master
Level 3:
Answers
1087
Questions
0
Helped
245237
Points
2442
It is not very obvious. The bar at the bottom of screen is your 'Task Bar'
1. Find an empty part of your Task Bar and Right Click on it
2. Select Properties
3. Near the bottom of the menu in 'Notification Area' tick Box 'Show clock'
While you are there, it shows all icons that are on your Task Bar. If empty find the 'Hide Tasks' box and untick
4. Tick Apply and OK
2answers
How to set specific dates to water with my T1030D? I don't need daily frequency for cool weather time. There is fequency dates to chooce on T1030, but not with T1030D.
1) Sept 2011.
If you have a T1030D timer instruction manual, then that would be helpful for many people.
Scan manual into .jpg format (file format) and then post images on Flickr.
Add a comment with link to those images so expert can access the information.
2) Currently the only instruction manual is the following, where you can also send information saying what your instruction manual says:
http://waterheatertimer.org/pdf/Instructions-for-setting-Gardena-T1030D.pdf
http://waterheatertimer.org/How-to-program-Gardena-C1060.html#manuals
3) That being said:
Let me add some guessing, and then you can add a comment with what you observe.
Between us we might be able to work out a solution.
4) I don't think you can set specific dates on either T1030 or T1030D
It appears the T1030D is a weekly timer, just like T1030.
The word 'date' does not appear in T1030 manual except 'date of purchase.'
http://waterheatertimer.org/pdf/Gardena-1030-MANUAL.pdf
5) T1030D: each day of the 7-day week is broken into hour 1 through 24.
Each day can have between 1 to 3 settings. I think this is frequency.
You can set the watering run-time from 1 to 120 minutes for each set time.
2helpful
Trying to set date/time for the first [ what is the wrench button?]
The "wrench" is NOT a button, it is an icon in the menu.
Press the MENU button. Press the Right/Left button to select the "WRENCH" icon The Setup menu appears in the center of the LCD. 3. Press the Up/Down buttons to select the Date option in the Setup menu. Press the MENU button. Press the Up/Down buttons to select a Date option from the Menu that appears: On selecting "On" the date will appear on the photo once it is taken. • On selecting "Off" no date will appear on the photo. • On selecting "Set Date" the Set Date settings screen will appear. You will be able to • change the date settings that will appear on the photo once it is taken. To Set the date: Press the Up/Down button to enter Set date option. 1. Press the MENU button. 2. Press the Right/Left button to select and highlight the Year, Month, Day, Hour, Minute, 3. Second and Date Format type. Press the Up/Down button to set the Date, time and format
Please...which is the wrench button? vivitar x327 trying to set up date/time. for the 1st time
1helpful
How do you change system date on ds
SOURCE: http://www.nintendo.com/consumer/systems/ds/time_date.jsp
Changing the date
  1. Remove all games from the Nintendo DS.
  2. Turn the system on by pressing the POWER button.
  3. Tap the screen using the stylus when the "Touch the Touch Screen to continue" message appears.
  4. When the main menu appears, tap the stylus on the Settings Menu Panel at the bottom middle part of the screen. icon_settings.gif
  5. Tap the calendar/time icon (the blue icon, second from the left). icon_clockdate.gif
  7. Tap the up or down arrows above the month, day, and year to change the values. When finished, tap the "Confirm" button in the lower right corner.
  8. Wait for the the confirmation message to disappear, then tap "Go Back," then "Quit," then "Yes" to exit. The unit will shut down automatically to save the settings.
I can change everything but the date. How can I change just the date on my watch. The model I have has 4 buttons (Mode, St/Stop, Set, and Light). Can someone tell me how to change nothing but the date?...
Hi 1234910,
To set the digital time and date on your Timex, please follow the steps below.
1. Press and hold the "Set" button for 2 seconds. The "Set" button is on the lower right side.
2. Press the "Date Advance" button on the upper right side. This will reset the seconds.
3. Press the "Change Mode" button on the lower left to set the hour. The hour will flash. Press the "Date Advance" button until the correct hour is displayed.
4. Press the "Change Mode" button again to set the correct 10s unit (first digit 1 or 0) for the minutes. Press the "Date Advance" button until the correct first digit of the minutes is displayed. Repeat this step to set the second digit of the minutes.
5. Repeat Steps 1 through 4 of this section to set the year, month, date and day and whether to use 12- or 24-hour time for your watch.
6. When finished, press the "Set" button (on the lower right) to return to the current time view and lock in your settings.
Hope it helps.
Thank you for using FixYa.
15helpful
I have a 'relaxed nature sounds lcd clock' with no instructions
Moderately difficult, but not impossible. ;) I picked up this clock @ second hand store with no instructions and was able to figure it out how to set it in about 15 minutes. I liked the calendar feature on the face and the LCD (as opposed to LED because I prefer my bedroom dark when I sleep).
When setting this clock, one of the keys is to pay attention to the the icons displayed on the face toward the lower left. Default "MODE" is time set. To set the time: Press "SET" followed by either "HOUR" or "MIN" while the display is flashing to increment the hours and the minutes to the correct time. As previously state, the default "MODE" is time set.
Pressing "MODE" one time accesses a secondary clock that you might use if you regularly travel to another time zone (new icon w/ 2 clocks appears). Setting the secondary clock uses the same method above.
Pressing "MODE" a second time accesses the first alarm setting (alarm clock icon starts flashing). Same method to set.
Pressing "MODE" a third time accesses the secondary alarm setting (second alarm clock icon appears and begins flashing). Same method to set.
Pressing "MODE" a fourth time accesses a timer (hourglass icon appears). Same method to set.
Pressing "MODE" a fifth time allows you to set the calendar (calendar year appears where the digital clock display was). Press "SET" to change the date: "HOUR" increments the month; "MIN" increments the day; "MODE" increments the year. Press "SET" again to exit.
Pressing "MODE" a sixth time returns to the default time set mode.
I hope this helps someone! God's blessings in Jesus Christ! ~Thomas
Entering an event in CALANDER recurring 3rd Friday of each MONTH
Go to calendar, choose a date & time, tap on details. You will see:
Time
Date
Alarm
Location
Category
Repeat --> this is where you choose the recurring selection, after that indicate done. And check.
Private
Palm Repair
If does hold a charge although it take al long time to charge and there have been eposides wihter I have lost the dates on the calander without reason. Thanks
1helpful
Nintendo ds
Setting the Time and Date
Changing the time
  7. Tap the up or down arrows above the hour and minute to change the time. When finished, tap the "Confirm" button in the lower right corner.
Changing the date
3answers
Aquatech Sport Chronograph Watch
quickly press the bottom-left button twice.
then, press the bottom-right button once, and then the top-right button once. this should add 1 to the day. keep pressing the top-right button until u get the right day, the press the top-right button again.
now, how do u change the time format back to twelve hr. ?
Dec 20, 2007 • Watches
Top Lenovo Computers & Internet Experts
Steve Sweetleaf
Steve Sweetleaf
Grand Canyon Tech
Grand Canyon Tech
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
