Hi there i need some help, I took the timing belt off my volvo penta 22tamd 105hp and i dont know the timing settings any chance you can help me
SOURCE: i need to put a timing belt on a daewwoo lanos
Go to mechanic and ask him to put a new timing belt, its the aftest way.
SOURCE: 1991 mazda b2200- timing belt changed
The keyway and or the dot on the crank should be line at 12 oclock. You will see a point on the oil pump housing to go by. On the camshaft the pointer will be at 12 oclock also. Use the O on the camshaft to the top at mark. Be sure to look at the dist. roter to make sure that it is pointing at the #1 spark plug wire. I could get 180 out of time. If you do it right it should start up right away. then you can use a timing light to finish it.
Good Luck [email protected]
SOURCE: setting timing marks on a 1998 Ford Escort
think u need a tool it locks the engine at top dead centre then u line cams up
SOURCE: replace timing belt holden vectra 2.2ltre
timing cover has marks on it,line it up with pulley,remove pulley and cover,check to see if any marks on camshaft.un do tensioner.to be sure make your own marks
