Hi trying to load a bluetooth dongal but have come up with an error code 43?
Phil
I don't know
Code 43 means that your device have problems in hardware, this can be simple to solve, ussualy this is caused by short-circuited cables, connectors,or the circuit board. Try to open up your device and try to see if there is any loose cables. One of the top places to be broken in a USB device is the connector between the USB and the Circuit board, try to connect them back by soldering process. N/b: you may see that the USB have 4 connector,, it looks like this: liil., the ones in the middle are data cables, that is the one which probably gave you a hard time.
Hey hey, like osborne382 metioned be sure to check the newest drivers for the device are installed on your computer.
But if you are still having trouble like i was -_- try enabling and disabling the driver thats what fixed mine.
Code 43
Windows has stopped this device because it has reported problems. (Code 43)Recommended resolution
One of the drivers controlling the device notified the operating system that the device failed in some manner. For more information about how to diagnose the problem, see the hardware documentation.
On the General Properties tab of the device, click Troubleshoot to start the Troubleshooting Wizard.
Learned from another site, its a EASY FIX. If you are on a laptop then shutdown, remove battery and the power cable, try to start to drain all juice from system. Then put battery and plug back in bam, its back. They get corrupted and this fixes it.
Same on desktop, shutdown, unplug and try to start, then plug back in and bam, its fixed.
Uninstall the driver... install again.. or else try add new hardware
Code 43 means that your device have problems in hardware, this can be simple to solve by applying any one of the following. first restore your windows to an earlier date or simply uninstall the driver (my computer---->properties----->Device manager) then shut down your computer and start it again....
for further mail me [email protected]
The Code 43 error is one of several Device Manager error codes. The Code 43 error will almost always display in the following way:
"Windows has stopped this device because it has reported problems. (Code 43)"
Details on Device Manager error codes like Code 43 are available in the Device Status area in the device's properties
im having the same problem with windows code 43
hi i have some problem when i plagin me USB from psp to me laptop hes coud not respondent can u give me answere about that error cod 43 pleas
My VGA Card is not working probebly and view this error with vista 32x
i have the same problem what can i do please tell me
Im dowload online
