I tried to unlock my SGH-A707 phone by this code #7465625*638*59258259* (the unlock code 59258259 was given by the store in California were it was bought) , but what came out is "Phone Freeze SIM Unavailable Please Contact Service Provider". Can you kindly help me unlock my phone. Thank you very much
unlock samsung sgh-a707
UNLOCK MOTOROLA SYNC
DO NOT TRY MORE THAN TWICE ... u can only do 3 attempts .. if the third don't work u will freeze your phone
Unlocking the Sync Instructions
The idea is that you are changing your phone's 8-digit unlock code to all zero's.
(1)Turn off your phone and remove the sim card.
(2)Then power the phone back on.
(3)Enter the following numbers on the keypad: *2767*3855# this will restart your phone,
(4)When your phone has restarted and powered back on you will enter the following into the keypad *7465625*638*00000000*00000000#
If your phone says wrong password, turn your phone off and put in an
unaccepted Sim Card into the phone (A sim card from another Service
Provider) and then start the process over again. If it says wrong
password even with the wrong Sim card, then you have reached your
second attempt, Do NOT try it again. Instead, go to Ebay and purchase
an unlock code.
(5)NEXT ENTER #7465625*638*00000000#
(6)AND THEN *#7465625# to check the locks....all locks should now be inactive or Off
If you find that some of your locks are still turned on, now
that you know your phone's unlock code, (00000000) you can use the
following codes to unlock individual locks on your phone (Where you see
the word Code you will put in your new unlock code, which is now
00000000:
#7465625*638*Code# = Disables Network lock
#7465625*782*Code# = Disables Subset lock
#7465625*77*Code# = Disables SP lock
#7465625*27*Code# = Disables CP lock
#7465625*746*Code# = Disables SIM lock
#7465625*228# = Activa lock OFF
Try *2767*3855#
but take your SIM card out first, or it'll delete everything on it. =)
FOR PEOPLE WITH PHONE FREEZE ON SAMSUNG- the #7465625*638*code# is not needed when you have the phone freeze just follow below.
I know how frustrating this was and i got it done by myself by experimenting since everything cant be googled that easily. i figured i can help anyone out. this has worked for 5 phones that i have done my self so 5 for 5 YESS!!! This is as satisfiying to me as watching micheal jordans final shot!
any ? contact me at [email protected]
ok i figured it out. for all those people that have gotten the dreaded phone freeze om samsung propel a767 or any other samsung phone so far not sure about touch screen.
first look for a local unlocker in ur area or somewher that can provide the codes and get the unlock code and phone freeze code. mine was only 20 for both and took less than 24 to retrieve. email me for his info.
insert sim that you want to use (tmobile). you get the screen which says phone freeze. type in the freeze unlock code which was given and the press the att logo/menu button.
**YOU WILL NOT BE ABLE TO SEE THE NUMBERS YOU ARE TYPING SO KEEP TRACK OF WHAT YOU INPUT**
after you have entered number and pressed button then you will get a network lock screen. this is where you type in ur unlock code. type that in press confirm and BAMM!!!! you are now able to use tmobile sim.
firset of all when the phone freezes, there is no screen to type in unless u go to make a call. ur not being specific. or do u have to get into the bios of phone i saw by going to star pund 69 pound and do it. can u do better and wehre did u get the unfreeze codes. that is useful. slow down . i need my phone unfrozen and dont wnt to pay that much
Got a phone freeze for samsung tocco lite s5230 plz help need da code
Samsung SGH-A411 phone freeze is there somebody can help me... pls email me at [email protected],,, and also this is my imei# 35702701110758/0,, SW VERSION A411DVGF3,,, pls help me about my phone i got only one phone i really need this for my communication pls!!! help me somebody! thanks
To unlock your Samsung phone you will need to enter the code. This code is
just a calculation of IMEI number of your phone. To find your phones
IMEI number -type *#06# into your phone or look under the phone battery.
There are different online services that will calculate the unlock code for your IMEI number. I can recommend this one (cheap and reliable).
Click here to unlock your Samsung A707.
Note: don't share your IMEI number on free forums like this.
My new hello kitty samsung touch phone asked me for network lock and i entered code wrond 3 times now it keeps saying''phone freeze sim unavailable please contact service provider''?????dont understand as i used my old sim card and i didnt have a network lock on as far as i know :(
The best website is www.samsungphonefreeze.co.uk - specialised in unlocking Samsung freezed phones !
Phone freeze
Hi there i am from south africa and got a samsung sgh-a767 from my friend in america and when i put in my sa sim it says something freeze ? please i need some help ...ek sal dit moer baie wardeer as ek hulp kan kry ...my email is [email protected] thank you soo much
I had this same issue. The response I got from Samsung is that only select AT&T store or Samsung themselves can unfreeze (reflash) a phone. Do not pay $18.99 for the "Samsung Remotre Client" software www.unlocksamsungonline.com. It is a scam. It doesn't work and it cannot work. They will not refund your money either. Two things to think about: 1st - any positive messages about the software are likely posted from the company itself. 2nd - call Samsung directly and they will reflash your phone for free including shipping. Although it takes a few weeks to get it back. It's really your only choice if your local AT&T store cannot reflash your phone. If you have had a similar experience with this company, please contact me about a group effort to contact the the FTC with complaints. Single complaints are ignored by the FTC. [email protected]
You can also try out www.UnlockSamsungOnline.nl they provide an online service for unlock and unfreeze of samsung, de A707 is also supported
I got a pre paid att phone that reads puk code i lost my code i need to get numbers
Help
Try using *2767*3855#
Samsung mobile got freezed when you enter unlock code for more than 10 times. many of samsung mobile are having roaming lock. And when you are out of that city your mobile got freezed.
To unlock such mobile you first enter unfreeze code and then enter network unlock code for samsung. Normally network code for samsung is of 8 digit.
There are also some app which generate unlock codes
http://mobile-cellphones.blogspot.com/2016/03/samsung-mobile-sim-network-unlock-pin.html
Call samsung
Please help me to un-lock the Samsung SGH-A707 cellphone Problem : Imei:35310301204249/0 02 Thanks a lot..
Pls help me to un freeze samsung GT-E1086i imei:358161047723661. big thanks
I tried to unlock my SGH-L170 PLS helpme
My d600 simlock password wont work... ive tried all the possible solutions written here but nothing worked out... help me plz....=(
Thx it worked out fine but all of my information deleted. why
SOURCE: phone freeze unlock code
have a look at a similar manual; may help
http://www.techteam.gr/mobile/specs/guides/SamsungSGH-E370.pdf
Hi ,
you can download unlock client from below site
http://www.mobile2mobile.net/unlock/Remo...
http://www.mobile2mobile.net/unlock/RemoteunlockingSamsung.htm?gclid=CLzQwIOBqYsCFQ-Wbgod2n3IjQ
PLEASE RATE ME...........................................
phn says sim lock ask for 4-8 digit code
same thin phone freese si locked after entry on unlck code one time now what do do
enter puk?
puk
Please help me out my phone says the same thing
Hepl me unfreeze it i have the same problem with the same phone
Help me out please i have the same problem my phone.. it got frezze too..
Phone Freeze SIM Unavailable Please Contact Service Provider". Can you kindly help me unlock my phone. Numbers are not displaying to enter the code. Thank you very much
my phone says, phone freeze SIM unavailale please contact
service provider. Can you please help me to solve this problem?
have called cingular they could not help called samsung the only place in america to take to or send it to is in texas there has got to be a code to unlock it from home without a unlocer box
thanks nick
phone frezze
Same thing, phone freeze sim unavailable please contact service provider.
Tried the code. Did not work. Help please
samsung sync sgh-a707 Phone freeze sim unavailable please contact service provider)
Our unlock codes (subside) different for each phone?
I HAVE THE SAME PROBLEM W/ PHONE FREEZING AND IT WOULD DEACTIVATE THE NETWORK UNLOCK. I TRIED TO WORK WITH FASTMULTILOADER V.3 TO RESET THE FIRMWARE BUT I CANNOT GET THE PORT SEARCH TO WORK....PLEASE HELP,,,
hey my phone says phone freeze and it is a samsung sgh-a707
well justl like everyone else, is just that my phone is already frozen. or it saids freeze
same problem
I have a Samsung sync and was given Subsidy unlock code for the phone took it to At&t to go thru the process and they had trouble with the instructions and subsequently tried it more than the allowed 5 times and now the phone is permanently frozen can anything be done?
Thank you very much
phone freeze
SIM unavailable
Please contact
service provider
pls! help me how to unfreeze my SGH-A411 Samsung...i already tried some of your code number but it didn't work. do you have any idea how to solve this problem thanks!
samsung SGH-A411 phone freeze is there somebody can help me... pls
me somebody! thanks
i have that same problem my samsung SGH-A707 is freezed up and i dont know how to put in the code because it dosent letme do anything but do emergency call's what can i do or how.... THANK YOU
I have samsung
model SGH-A707
FCC ID: A3LSGHA707
SSN: A707GSMH
PLS i want to unlorck networck
I Am in naigeria
my Email : [email protected]
I tried unlocking my att a707 now i get Phone Freeze SIM Unavailable Please Contact Service Provider
I can make and recieve calls but there is no images on sceen it completely black. no phone book either.
tried to unlock my A707 and it keeps telling me its in "freeze mode". How do I get around this?
dear good friend pls i have samsung a707 when ever insert simcard it tell me phone freeze contact provider can u hel me solve this problem
Phone in freeze mode, how do you remoze the freeze from the sync a707?
ho lo stesso problema di tanti altri utenti.
Ho un samsung SGH-Atot AT&T e essendo in italia non posso usarlo con un gestore italiano perchè apèpena inserisco la nova sim mi chiede un codice per sbloccarlo.
Cosa devo dare?
i got a phone freeze trying tu onlok y phone
i went to inlocked my a707 samsung phone
PHONE FREEZE SIM UNAVAILABE PLEASE CONTACT SERVICE PROVIDER
my phone has freezed and i don't have the code to unlock it. i have presonal stuff on it and can't get it. number photos videos etc. can you help me please. i have a samsung d500.
i tried to unlock my a707 with a code i was givn but now its frozen
it no work
phone freeze
my phone is Samsung Propel SGH-A767, appears on the display:
"Phone Freeze",
"SIM Unavailable" &
"Please Contact Service Provider"
please help me solve this.
thanks.!
All the locks in my phone samsung a707 are off except the network lock can any one help me please !! the phone thus say freeze sim unavailable
i got a samsung u700 and it the same thing over and over again
plaease help me
PUK lock need PUK code
I got an unlock code for my Samsung Eternity but it didn't work because it said it was phone freeze
Plz i have a samsung Zv10 and it says PHONE FREEZE what can i do ? pls email me at [email protected]
it is the same problem that you have posted .Iwas giving tha code by att
with the hlep from them, we conld not unlock my phone it keep saying that the phone had freeze on it. Are to put my sim card in
i tryed to type my pin code in it clep saying it was not write and it locked me out it wont do nothing
I have a telus phone that kept freezing every time i click media to go to picture or video it freeze .It's because of the memorize chip
SAME SCREEN APPEARS ON MY PHONE....WAT TO DO?
i have samsung eternity. it is freezed. how can i unfreeze it pls do tell me someone??????????? pls mail me at [email protected].
thanx
I tried to switch my AT&T Phone to a T-Mobile Carrier. but the phone said Phone Freeze SIM Unavalible please contact service provider. i have a SamSung Muse.
i want you to please give me the unlocked code number for the model mentioned above, thanks
