Mazda Master
- Posted on Jun 25, 2009
Re: Where is the fuel pump located and what does it look...
I believe this is same truck as Ranger
Pump is in tank
Removal
NOTE: On some vehicles, fuel gauge sending unit is not available separately. On those vehicles, to replace sending unit, replace entire fuel pump .
- Remove fuel tank as described in this section.
Removal and Installation
NOTE: Make sure fuel tank is properly supported during removal and installation procedures.
- Drain fuel from fuel tank .
- Loosen fill pipe clamp.
- Remove bolts securing shield and bracket assembly to frame (5005) and remove assembly from vehicle.
- Remove fuel tank filler pipe from vehicle.
- Support fuel tank .
- Remove bolts and nuts from rear fuel tank support strap and remove rear fuel tank support strap .
- Remove bolt and nut from front fuel tank support strap and remove front fuel tank support strap .
- Lower fuel tank .
- Remove fuel feed hose at sender push connector.
- Remove fuel return hose at sender unit push connector.
- Disconnect sender and fuel pump electrical connector.
- Remove fuel vapor hose from fuel vapor valve .
- Lower fuel tank from vehicle
- Remove fuel tank to bench. Remove any dirt that has accumulated around the fuel pump attaching flange so that it will not enter the fuel tank during fuel pump removal.
- Turn the fuel tank sending unit locking retainer ring (9A307) counterclockwise with the Fuel Tank Lock Ring Wrench Tool T90T-9275-A or T86T-9275-A and remove fuel tank sending unit locking retainer ring .
- Remove the fuel pump and sender assembly.
- Remove fuel pump mounting gasket (9417) and discard.
- If necessary, disconnect spade connector and remove two screws and fuel gauge sending unit.
