One For All URC-3021 Remote Control Logo
A
Anonymous Posted on May 29, 2014
I have a URC 3021 universal remote and need codes for an Orion tv
Level 3:
Top Expert:
  • One For All Master 76,851 Answers
  • Posted on Oct 15, 2016
One For All Master
Level 3:
Top Expert:
Answers
76851
Questions
30
Helped
14994158
Points
237762
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. The site has set-up code list & set-up procedure to many popular brand remote controls. The site has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Set-up code list to many brand remote controls also is given. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Programming Notes
• If your device does not respond to the remote after trying all codes listed or your brand is not listed in the code list, use the Auto Code Search method to program your remote.
• Sometimes the first code that "works" with your device may operate only a few functions of your device. There may be another code in the code list that performs more functions. Try other codes from the code list for more functionality.
This is a trial and error procedure; and quiet time consuming. You might have to check different codes said for your device.
Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window" to get gathered related posts.
Jean Philip
Level 2:
Habit-Forming:
New Friend:
  • One For All Expert 88 Answers
Jean Philip
One For All Expert
Level 2:
Habit-Forming:
New Friend:
Answers
88
Questions
0
Helped
71162
Points
462
Check this codes 0184, 0209, 1479, 0479 for Orion TV.
Other codes see in the URC 3021 owner's manual at this link One For All URC 3021
5 Related Answers
Gigatech
Rafael Ortiz
  • 259 Answers
  • Posted on Dec 12, 2007
SOURCE: NEED CODE
Celera 0765
Magnavox 0054, 0706, 0030, 1454, 1254
SEARCHING FOR YOUR CODE
If your device does not respond to the remote control after trying all codes
listed for your brand, or if your brand is not listed at all, try searching for
your code.
NOTE: Before performing a code search for a DVD player or a VCR, turn on the device and
insert the required media.
For example, to search for a code for your TV:
1. On the remote control, press TV once.
2. Press and hold SET until the LED (red light) blinks twice,
then release SET.
3. Enter 9 - 9 - 1.The LED will blink twice.
4. Aim the remote control at the TV and slowly alternate
between pressing POWER and TV. Stop when the TV turns off
(after pressing POWER). If the device does not have a Power
key, you can substitute another function, such as digits 0 ~ 9 ,
CH, or PLAY).
NOTE: In the search mode, the remote control will send IR codes from
its library to the selected device, starting with the most popular code
first.
5. To lock in the code, press and release SET.The LED will
blink twice.
6. To search for the codes of your other devices, repeat steps
1 through 5, but substitute the appropriate device key for
the device you are searching for.
here is the maual for your remote:
http://www.ofausa.com/remote_manual/URC4...
Anonymous
  • 1027 Answers
  • Posted on Jun 05, 2008
SOURCE: urc-3021 codes
link to pdf manual
RCA 0047, 1047, 1147, 1247, 1347,
1447, 1547
Anonymous
  • 2335 Answers
  • Posted on Oct 13, 2009
SOURCE: Need Universal Remote codes for Orion tv- One for All Remote
The TV codes for a URC-3021 and an Orion TV are:
0236, 0463
These are the steps to program your remote:
To setup your URC-3021 for a TV, these are the steps:
1. Turn on your TV.
2. On the remote control, press TV once.
3. Press and hold SET until the LED (red light) blinks twice,
then release SET.
4. Enter the first four-digit code for your device. If performed correctly,
the LED will blink twice. If the LED did not blink twice, repeat steps 2 through 4 and enter the same code again.
5. Aim the remote control at the device and press POWER once. The device should turn off. If it does not, repeat steps 2 through 5, trying each code until you find one that works.
Anonymous
  • 2335 Answers
  • Posted on Apr 24, 2010
SOURCE: I need the codes and manual for a universal remote
I can help you with your URC-3021 Universal Remote Control issues.
The codes for Sylvania TV's are: 0054, 0030, & 0171.
For complete instructions on entering the URC-3021 remote codes, please refer to my posted Fixya Tip One For All URC-3021 Code Entry.
I hope that helps.
_______________________________________________
Reassign URC-3021 Device Key
Urc-3021 Code List Download
One For All URC-3021 Code Search
Anonymous
  • 2335 Answers
  • Posted on May 29, 2010
SOURCE: URC-3021 Remote Control: I need the codes for tv's....
Without knowing what brand of TV you would like to control, may I recommend using the URC-3021 One For All URC-3021 Code Search, or refer you to the One For All URC-3021 Code List?
I hope that helps.
One For All URC-3021 Manual
One For All URC-3021 Reassign Key
1helpful
I need programming codes for Orion TV to get my remote working.
The codes for Orion TV's are: 0236 & 0463.
I hope that helps.
Code
The codes for Orion TV's are:0522, 0571 & 0717.
I hope that helps.
Is there a code for orion tv
I hope that helps.
Need remote for a one for all - for a orion tv
I hope that helps.
Need to reprogram for a Orion 13 "
I hope that helps.
I can not change channels or the volume on my sharp tv I replaced the batteries on the remote control is the converter box to blame?????????????
I can help you with your URC-3021 Universal Remote Control.
Sometimes taking the batteries out will cause the remote to need to be reprogrammed.
The codes for Orion TV's is: 0093.
I hope that helps.
5helpful
0236, 0463
1. Turn on your TV.
then release SET.
I NEED CODE FOR URC-3021 UNIVERSAL REMOTE FOR AN ORION TV
I hope that helps.
Need code for orion 22" MTS stereo tv
The Orion TV codes for an All in One URC-3021 are 0236 or 0463.
If your request has been mistakenly posted in the URC-3021 forum, please repost with the full model number of your remote, as these codes may not work with other remotes.
Need code for urc3220 and instructions
I can help you with your URC-3220 Universal Remote Control issues.
The URC-3220 codes for Orion TV's are: 0236, 0463, & 0179.
For complete instructions on entering the URC-3220 remote codes, please refer to my posted Fixya Tip One For All URC-3220 Code Entry.
I hope that helps.
One For All URC-3220 Manual
One For All URC-3220 Code List
One For All URC-3220 Code Search
One For All URC-3220 Reassign Key
Top One For All Televison & Video Experts
ExpressFiX
ExpressFiX
ZJ Limited
ZJ Limited
Are you an One For All Televison and Video Expert? Answer questions, earn points and help others
