Hard reset LG Optimus V VM670 full reset
WARNING: All of your data will be lost!
1. Turn the power off.
2. Press and hold the following keys for over 5 seconds: VOLUME DOWN key + HOME .
3. When the power turns on, release these keys.
Settings > Privacy > Personal data >Factory Data Reset
If you've entered the wrong information 5 times, you will need to wait 30
seconds before you can attempt again.
When you can't recall your unlock Pattern, PIN or Password:
If you've set up a Google account on the device, tap the Forgot pattern? button. You will be able to unlock the device with your Google account user
name and password.
If you haven't created a Google account on the device, you will need to perform a factory reset.
(CAUTION! If you perform a factory reset, all user applications and user data will be deleted. Please remember to back up any
important data before performing a factory reset.)
Tony
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/tony_a41fa0b801734e2f
SOURCE: My daughter has an LG Touch GW620 phone and has
give it to lg service center and re-install ur os again.. simple
SOURCE: i attempted my unlock pattern to many time now my phone is locked
you will have to do a master reset....you will loose everything on the phone....it is important that you create a google profile, which will back up all your contacts....
if this doesnt work is because your phone doesnt have the harware keys firmware update... need to take it to a repair center and have do a software reflash
SOURCE: i need to hard reset
Try this method below on how to hard reset Sony Ericsson Xperia X10:
1. Turn the power off first. If the Sony Ericsson Xperia X10 is frozen,
take the battery out from the device and then reinsert it back again
after a few seconds.
2. Hold the Left and Right Keys located beneath the LCD Display
3. Press and release the Power Key
4. Just then follow the on-screen instructions that appears to hard reset the Sony EricssonXperia X10
SOURCE: i have an lg gt540
It is very easy tounlock LG cellphone. You can unlockyour LG Cellphone by follow simple instruction.Contact your carrierprovider for free unlock code.otherwiseno one give you free.you can get MEP code for your LG at cheapest rate by MEP unlockcode provider .after unlocking you will be able to use any GSM Sim.
SOURCE: i have a LG Optimus
i have a LG Optimus S and i forget my pattern passcode and my e-mail isn't working how can i unlock it
