Cub cadet Z Force 48 inch zero turn. Was cutting grass, pulled both levers back to back up and turn around, blades re-engage. Diagnosed no fire to PTO. Replaced PTO switch. Cut grass 1-1/2 hours, everything worked fine until pulled levers back to back up, blades went off, never re-engaged. Need help with problem, haven't found anybody yet that can help. Thank you, Joshua
I hope this will help you...under the side panels on each side of the mower, there are "reverse lockout safety switches", they are supposed to stop the blades when both handles are pulled back. If one or both of the switches are out, the deck will not engage. Also, under the right side panel (when sitting on seat) there should be 3 relay switches, the one closest to the motor controls the PTO., if this is out, the PTO will not engage.
Left side hydrostat is very weak, wont go up hill.
One lever on Z Force club cadet hard to move
