Well you have a few options here to try and fix this issue.
First I would check the kill switch boot and make sure that its still intact. If not then the kill switch is the problem.
Second thing is checking all the fuses
Third if all checks out ok, your going to want to run a few tests on your CDI. Once you open the front cover, there are two wires a black and a white. your going to want to disconnect those and then check spark or start. If spark/runs then its your kill switch if that does not work your going to want to get a manual and a OHM/multi meter and test your CDI
I’m happy to assist further over the phone at
https://www.6ya.com/expert/jeremy_677dced97ad9bddf
