SOURCE: HTC Touch Viva is not charging
You have to check first the charger you can used multitester in position DC volt to make sure the voltage no problem, if in the plug no voltage maybe the cable damage, or the soldering on pcb circuit bad,you can try with another charger first to make sure where is the problem.
SOURCE: battery power was very low. plugged Drsire into
Please remove the charger and take the battery out of the phone for one minute. Whilst the battery and charger are out press and hold the power button for 10 seconds to drain any residual power from the phone.
Replace the battery and charger and after a minute power up again.
If the issue is resolved or if it persists please do let me know.
Many thanks for using FixYa
