My Kenmore 80 series washing machine stopped spinning during a spin cycle. I had the machine paused with the lid up adjusting the load. When I lowered the lid it made a sound like something snapping or breaking. Now it no longer spins. It does still make a noise like the motor is turning.
Drive belt probably snapped...if you want to fix it yourself to save money...google the model make of machine along with the part you require and add Amazon...which should link you to Amazon to enable you to bug replacement part...same goes for finding replacement items on EBay.....if you take thenrear panel of the machine off..then you will see if the belt has broken or simply slipped off.
SOURCE: Kenmore Series 70 Washer Model 110
That would be your lid switch that has went bad. Remove the console caps, then remove the two screws that hold it down (sometimes these screws are in the rear of the console) Rotate the console out towards you gently, then fold it up and over the top of the unit. You see 2 gold colored hold down clamps on top, and either side of the unit. You will also see a wire and disconnect going down through the cabinet on your right hand side. Disconnect these wires (be sure unit is unplugged) and rotate the whole cabinet towards you. You remove the two screws that hold the switch in place and a 5/16" screw underneith that holds the ground wire. Unclip the connector from the rear top of the cabinet and remove the switch. Be sure to bring your whole model number 110.************** when you get the new part, there are two of these, and they look the same except the wire ends are different. Good luck Jim
SOURCE: kenmore series 80 washer makes loud knocking noise during spin cy
Unless your front loader is set firmly on concrete
and leveled to perfection, the force of a heavy wash load spinning in
excess of 1000rpm will create a bit of vibration and noise.A firm footing is your best defense against to much movement.
Also due to the earlier movements during the spin cycle, the
shocks that are used to dampen the spin cycle might have been broken or
damaged.
If the problem persists inspite of proper levelling, please do check for the shocks or might have them replaced them for good.
SOURCE: Kenmore 80 series 110 washer making loud noise during final spin
Make sure all springs are still in their place tilt the machine back and look under it and you can see them. 2nd all legs must be level as well as the floor.
SOURCE: Kenmore 80 Series washing machine - loud banging at end of spin
With the lid open, set the cycle to spin and press the lid switch button with a pen. Wait until the drum gets to full speed and release the lid switch. If the drum makes a knocking/ thumping noise and doesn't stop spinning within 2-3 seconds, the basket drive block is worn and needs to be replaced. (The basket drive block is located on the gearcase drive shaft, under the tub and agitator) If this has been happening for a long time you may need to replace the brake and drive tube assembly as well.
Basket drive block part number is 389140
If that's not it, let me know and I will try to help you further.
SOURCE: Squeaking washing Machine during spin cycle
Hi
Loks that your machine is pretty old and hence the belt has hardened making a squeaking noise.
Good fix is get a new drive belt.
OR
Quick fix is you could put some oil on the drive belt..... it will work for now but not a permenant solution.
Regards
Berry
