SOURCE: hp laserjet 3380
Not a easy task on one of these, all covers off, doc feeder and scanner have to be disconnected from main pcb and then remove entire assemblys (Entire top of machine ends up sliding back and up/off), then your getting closer to removing fuser..brackets frame off...many screws, if you aint done it, very easy to break.
I broken a few learning but it's the only way to know! There is a Service manual but It is not publicly allowed to distribute it, and to be honest they are harder to understand than the printer... just be logical, patient, gentle, steady, or be smart replace.
SOURCE: HP laserjet 3380 needs fuser replaced
Unfortunately, the scanner assembly must come off. It's all screws and covers from then on.Try buying a service manual from eBay.
SOURCE: How can I change the baud rate on my HP Laserjet
There is no baud rate to this printer, it's either parallel cable or USB cable. Baud rate refers to the old serial cable connections, com1 or com2. You can add memory to this printer to make it print more documents faster. Try this location:
http://reviews.cnet.com/multifunction-devices/hp-laserjet-3380-all/4505-3181_7-30822993.html
SOURCE: HP laserjet 3380 baud rate faxing
go to folowing link and refer all your setup it's only for FAX issues
http://h20584.www2.hp.com/hpgt/guides/select?prodTypeId=18972&lang=en&cc=us&prodSeriesId=378060
SOURCE: How do I set the baud rate for faxing for a HP
go to foliwing link to setups fax in HP printer
