Computers & Internet Logo
p
peggy Posted on May 29, 2014
How to block a particular number from calling our casio ravine cell?
roselle nitoral
Level 1:
New Friend:
  • Contributor 21 Answers
  • Posted on Jun 24, 2014
roselle nitoral
Contributor
Level 1:
New Friend:
Answers
21
Questions
0
Helped
5775
Points
30
There is no option on this phone to restrict the caller ID.
If the number is XXXXXX up as 'Restricted' then it can only happen if you dial *67 at the beginning of the number you want to call to block you caller ID information. Or, you can also call Verizon and have caller ID blocked for every number.
If this is happening for every number, then you will need to call Verizon and have them deactivate the caller ID restriction.
Casio G'zOne Ravine 2 C781, how do i conect it to theinternet
Its worth a look in your phone system settings (possibly under 'Mobile + Sim settings) to make sure Data Connection is "ON"
Won't receive calls
turn the ophone off and then back on
How do i change the time on my verizon ravine 2 from military time to 24 hour time?
Hi Marilyn - As military time is the same as 24 hour time, did you mean you'd prefer to display 12 hour time rather than 24 hour time?
The phone's manual explains how to alter the clock format so I've copied the relevant part for you.
DISPLAY SETTINGS (page123 of manual)
EASY SET-UP
To set up display options using the Easy Set-up Wizard:
1. Press the Center Select Key [MENU], select Settings & Tools and press the Center Select Key [OK]. Select Display Settings, press the Center Select Key [OK], select Easy Set-upthen press the Center Select Key [OK].
2. Select the display settings including the PERSONAL BANNER, DISPLAY BACKLIGHT, KEYPAD BACKLIGHT, MAIN WALLPAPER, DISPLAY THEMES, MENU LAYOUT, DIAL FONTS, MAIN CLOCK FORMAT, FRONT CLOCK FORMAT, and press the Center Select Key [SET].
To skip the step, press the Right Soft Key D [Skip].
MANUAL FOR CASIO RAVINE
http://nec-casio-mobile.com/support/download/GzOneRavine2_Manual.pdf
VERIZON FORUM TOPIC - CASIO RAVINE CLOCK
Casio zOne Ravine 2 Support
Casio g'zone phone with broken screen main screen.
This is most likely a broken data ribbon. It is a few very thin wires that connects the mother board of the phone to the screen and can easily break with flip phones. It can be replaced and new data ribbon is cheap.
The main screen on my Casio G'zOne Ravine (C751)
Let it charge for 24 hours before trying again. Battery may be too weak to light up the display yet.
Sep 24, 2013 • Cell Phones
14helpful
3answers
How to block a call for A PARTICULAR NUMBER IN C2-01
Hi, I have a nokia E71 and i want to block calls from a particular country code. Can call barring feature help me in blocking those numbers from calling me?
that will not help you to avoid calls from particular Number for that you should call your service provider they will charge you per month some amount & they will block that particular number which you give them.
Regards,
Harish
// Feel free to vote this answer with 4 thumbs up &
Testimonials //
Top ooVoo Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you an ooVoo Computer and Internet Expert? Answer questions, earn points and help others
