Do i need to replace the whole stem or do they sill rebuild kits
SOURCE: I can't get hot water from the pegasus shower valve
The antiscald device needs to be adjusted. It's behind the escucheon and determines the amount of hot water flow.
SOURCE: Replacing stems on old hot and cold shower valves
Just replaced the same exact stems... one seated fine, the other spun and wouldn't turn off. I added an extra washer to that one... it pushes the seat in just a bit further.
SOURCE: low flow hot water in Delta Shower
If your water heater is old or has been recently replaced, it will slough off debris that will get caught in the hot water supply side of the faucet. You have to disassimble the faucet and use a dental pic to remove the debris from it. This is a real common occurance. You can also try to flush out that side by removing the parts and then slowly turning on the water without the parts inside. Be careful not to flood your bathroom when you do this. But usually you have to dig it out. I have spent as high as 3 hours digging the liner from the dip tube of a water heater out of a faucet.
SOURCE: Speakman shower faucet washer replacement
Keep unscrewing, to the left. Past the point that would normally be the full "on" position for the valve. I've just removed my Speakman Kent shower stem, and because it is damaged where the washer attaches, will have to replace it (both of them).
SOURCE: Thank you for reading this. I am a non-technical
You didn't mention what model you have. Here is a link to their web site. You can download a manual, that has detailed instructions on how to adjust. You should have a thermometer to measure water temperature to adjust properly. Go to : http://www.groheamerica.com You can identify your model, and then download the technical product information. Also check the temperature of other faucets in the house to be sure they are getting hot enough, and not a water heater temp problem.
