Konica Minolta bizhub 350 All-In-One Laser Printer Logo
A
Anonymous Posted on May 28, 2014
Unable to scan mail
I am getting an error e7300 it give host name and as well ip address but still unable to scan email
Norman Weimar
Level 3:
  • Konica Minolta Master 7,035 Answers
  • Posted on Dec 28, 2015
Norman Weimar
Level 3:
Answers
7035
Questions
Helped
1913072
Points
11959
Using static or DHPC ip addressing is the proper port set up SMTP and or POP3. Mail server correctly set up.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
5 Related Answers
Anonymous
  • 8 Answers
  • Posted on Feb 02, 2008
SOURCE: Problem in configuring IP address in Konica Minolta bizhub 210 Copier, Printer, Fax
Is there network card is installed in it, if yes then you can configure it with your network go to machine Manu in machine control panel and the in network settings here you can give the IP address and subnet mask after then reboot the machine.
If network card is no installed behind the machine then you can use its built-in USB or and parallel printer without NIC card.
A
Anonymous
  • Posted on Mar 23, 2008
SOURCE: getting the ip address
To print out machine current ip address, go to utilities, user setting, printer setting, print reports, configuration.
Anonymous
  • 167 Answers
  • Posted on Jun 09, 2008
SOURCE: Can't get the setup correct to Scan to Email
The basic requirements are:
The copier must have a valid email address to log in to the server and send messages.
Your network settings must reflect the server and protocol being used.
Usualy mimicing the settings from a computer works as it is basiclly the same thing.
The device should give you different errors if it cannot locate the server as compared to unable to log in.
Manuals:
help.bt.konicaminolta.ca
Bubbabear64
Tim Babcock
  • 2794 Answers
  • Posted on Oct 20, 2008
SOURCE: Scanning to C352 server connect error
Check you smtp server settings in admin settings. Verify there correct. If your smtp server needs your email address and password to send, that should be populated as well under them smtp authentication settings.
Anonymous
  • Posted on Dec 22, 2008
SOURCE: Bizhub 250 scan to email error
Change your account information from external to internal, i.e. yourmaildomain.com to yourADdomain.local. Change on the scan account as well as the email addresses.
1helpful
Xerox WC 3220 scan to e-mail problem with external smtp server(ISP). I am trying to configure the scanner to send mail. I follow up the instructions in the manual. When I try to test it I got smtp error ...
You can always find answers to your Xerox questions at www.xerox.com/support .
The 3220 does NOT support SSL, please verify if your email service is requiring SSL transmission. (Port 445 or 587 are indicators of SSL email requirements.) There are free email providers that will still send on port 25 without SSL. Xerox does not provide a list however so you will need to research these yourself.
Instructions for setup scan to email below:
Configure the Machine for Scan to E-mail
IMPORTANT: Obtain the following information from your e-mail service provider before configuring the machine for Scan to E-Mail.
  1. What is the host name or IP address of the SMTP server?
  2. What port number does that SMTP server require?
  3. Does the server require authentication login? If so, what format does the server expect the login? (Does the server require the full e-mail address or just the part before the @ sign?)
  4. Does the e-mail server require POP3 before SMTP authentication? If so, obtain the POP3 settings (POP3 host name or IP address, port number, and login name/password).
  5. Does the server require SSL or TLS encryption? If so, ask your e-mail provider to provide you with an e-mail server that does not use SSL or TLS encryption as the printer does not support SSL/TLS encryption for e-mail authentication.
    NOTES:
    • If you are provided with a new e-mail server to use, questions 1 - 7 will need to be answered again.
    • Xerox does not provide a list of e-mail providers that do not require SSL/TLS encryption for e-mail authentication.
    • If unable to find an e-mail service that does not require SSL or TLS encryption, See theRelated Items below for information on how to Install the Network Scan program for a Windows OS or how to Install the USB Scan Driver for a Macintosh OS. Once the scanned file is stored on your computer, it can then be e-mailed from your computer as an attached item/file in a new e-mail.
  6. What is the attachment size limit on the account on that server?
  7. What 'From' address will the printer use for Scan to E-mail? The From address should be a valid e-mail address for the e-mail server that the printer will use. Ask the e-mail provider if authentication is required if the login name (above) is allowed to be used for the From address the printer will use.
    If you do not know the answer to the questions above, contact the people that control the e-mail server you want the machine to use for Scan to E-mail. The following parties can provide you with additional assistance:
    • If the e-mail server is inside your company's network, contact the E-mail Server Administrator to obtain the required settings.
    • If the e-mail server is outside your company, contact the Technical Support for that e-mail service to obtain the required settings. This may be your Internet Service Provider (ISP), or a 3rd party E-mail Service Provider.
Configure the Machine's E-mail Settings Using CentreWare Internet Services (CWIS)
After you have obtained the above information, configure the machine's e-mail settings using CWIS.
  1. Access CWIS. See the Related Items below for additional information.
  2. Click on the [Properties] link.
  3. In the Properties section on the left side of the window, click on the [+] symbol next to theProtocols folder to expand the list of options.
  4. Click on the [SMTP Server] link.
  5. Click on the [IP Address] or [Host Name] radio button.
  6. Enter the IP address or domain (host) name of the SMTP (e-mail) server in the field provided.
    NOTE: If you use an IP address for the SMTP server, verify that the IP address for the server will not change. If the SMTP's server IP address changes, the machine will be unable to Scan to E-mail until the machine's SMTP Server address entry is edited with the new SMTP server IP address. If necessary, contact your E-mail Administrator to verify how the IP address has been assigned to the SMTP server.
    NOTE: If using the domain (host) name, make sure DNS is enabled on the machine. By default, DNS is disabled. To enable and configure DNS settings, click on the Properties tab, click on the TCP/IP link under the Protocols folder, enter the required DNS settings for your network in the DNS/DDNS field, and then click on [Save Changes]. Contact your Network Administrator to obtain the correct DNS settings.
  7. Enter the port number used by the e-mail server, from 1 to 65535, in the field provided. The default port number is 25. If you use an IP address for the SMTP server, verify that the IP address for the server will not change.
  8. If authentication is required, insert a check mark in the SMTP Requires Authentication check box.
  9. In the SMTP Server Login Name field, enter the SMTP login name.
  10. In the SMTP Server Password field, enter the SMTP password and then retype the same password in the Verify Password field.
  11. If the E-mail server requires POP3 before SMTP authentication, continue with step 13. Otherwise skip to step 17.
  12. If POP3 before SMTP authentication is required, insert a check mark in the SMTP requires POP3 Before SMTP Authentication check box.
  13. In the POP3 Server and Port field, enter the IP address or domain (host) name of the SMTP (e-mail) server and the port number. The default port number is 110.
  14. In the POP3 Server Login Name field, enter the POP3 login name.
  15. In the POP3 Server Password enter the POP3 password and then retype the same password in the Verify Password field.
  16. Click on the [Save Changes] button.
  17. In the Properties section on the left side of the window, click on the [+] symbol next to the E-mailfolder to expand the list of options.
  18. Click on the [E-mail] link.
  19. Click on the [E-mail Setup] link.
  20. In the Default [From:] Address field, enter the from E-mail address that the printer will use for sending E-mail.
    NOTE: If you do not want the from address that the printer will use to send E-mail to be automatically copied on any E-mail that is sent from the printer, make sure that the check box next to Always prompt for file format setup before scanning is not checked. Additionally, the following default settings can be set for Scan to E-mail:
    • Default Original Type - Available options are: Text, Text/Photo, and Photo
    • Default Scan Resolution - Available options are: 100 dpi, 200 dpi, and 300 dpi
    • Default Attachment Type - Available options are: PDF, TIFF - Multi Page, and TIFF - Single Page
    • Default Scan Color - Available options are: Mono, Gray, and Color
    • File Format Setup Prompt - Leave this box unchecked if you do not want to be prompted for the file format each time you Scan to E-mail.
    • Conformation Sheet - Available options are: On Errors Only, Always, and Off
  21. Click on the [Save Changes] button.NOTE: See the Related Items below for information on how to Scan to E-mail. When Scan to E-mail is successful, it is recommended to print a copy of the SMTP Server settings and E-mail Setup settings from CWIS for your records. If Scan to E-mail fails in the future, refer to these settings.
Configure Additional E-mail Security Settings (Optional)
For additional security when sending e-mails, the machine can be configured to require the sender to be authorized prior to using the machine's Scan to E-mail service. This is an optional security feature for Scan to E-mail and is disabled by default.
Authorized users for Scan to E-mail can be configured using CWIS. Up to 2,000 users can be registered.
  3. In the Properties section on the left side of the window, click on the [+] symbol next to the E-mailfolder to expand the list of options.
  4. Click on the [User Authentication] link.
  5. Insert a check mark in the Enable Auth User check box to enable user authentication.
  6. If necessary, insert a check mark in the Enable Guest Account check box to allow guest access. If this option is enabled, enter a login name and password for the guest account in the fields provided.
  7. Click on the [Add] button to add new accounts.
  8. Enter a username, an authentication ID, a password and an e-mail address in the fields provided.
  9. Click on the [Save Changes] button. The user will be added to the User Authentication List.
1helpful
Copystar CS-C3225 color copier scanner. The Scan to Email quit working. It says Unable to find SMTP server. A Windows box and an iMac print to this. We updated the driver on the iMac for this and n
Updating a driver would not affect the mail server settings. could be a firewall issue but i doubt it. is the smtp server on your lan or are you using a hosted mail solution? the only things that matter there are the ip address of the smtp server, authentication, ssl (or not), port numbers, default from address, dns settings, and message size. the mail function is totally independent from you computers operation unless an on site server or workstation is hosting the smtp server.
1helpful
3answers
I need to scan to email using the c353 konica Minolta. I used the same settings that the copier has that is working, but this one i set up won't scan to email.
This are the the information you need to setup scan to email and maybe you know how to access the web browser to setup the network. first you need to know the smtp host name or ip address, second you must create a valid email address for the copier. To access the web browser input the ip addrress and press enter click administrator and the password is 12345678 or 8 zeros. there are tab system info print, scan and network. click the the scan tab. choose scan to email first thing you will see enable scan to email smtp ip address or host name. enter the right smtp. witch this you can get to your mail server. do not change the port # and that is 25. Input administrator email address and the machine email address and turn on the authentication enter your user id and a password iof there is any.
3helpful
3answers
Xerox Workcentre 4150 having problems setting up Scan to Email
  1. Print a Configuration Report. See the Related Items below for additional information.
  2. The following fields should be set as indicated for scan to e-mail to be properly enabled and set up:
    1. Under the Installed Options section, Email field: Installed / Enabled
    2. Under SMTP Setting section, SMTP Host Name or SMTP Server IP Address field requires a valid entry.
    3. Under SMTP Setting section, Default E-mail Address field requires a valid entry.
If the WorkCentre is a network connected configuration, it will arrive with the E-mail service enabled. The copier-only model is not network connected and cannot perform Scan to E-mail.
NOTE: E-mail is enabled at factory, by default. If the E-mail button is not available on the All Services screen, enable E-mail in the Tools mode.
Before starting the setup procedure, make sure the following items are available or have been performed:
  • Make sure the WorkCentre is fully functioning on the network. See the Related Items below for additional information.
  • E-mail service must be available (enabled).
    NOTE: E-mail is available by default.
  • Make sure the TCP/IP protocol is set up and the HTTP protocol is enabled on the WorkCentre; both protocols must be fully functional.
  • Obtain the IP Address of a functional SMTP mail server that accepts inbound mail traffic. See your Network Administrator for additional assistance.
  • Make sure the DNS settings are configured correctly and obtain the Domain Name address, if applicable. See your Network Administrator for additional assistance.
  • Create an E-mail account which the WorkCentre will use as the default 'From' address.
  • Test the E-mail account by sending an E-mail to the WorkCentre account. This task should be completed at a mail client on your network that supports SMTP.
To access E-mail settings using Internet Services from a web browser window:
  1. From a computer, open the CentreWare Internet Services (CWIS) window. See the Related Items below for additional information. The main CentreWare Internet Services window will be displayed.
  2. Click [Properties], click [Connectivity], click [Protocols], and then click [TCP/IP].
  3. Enter the Domain Name in the Domain Name field. For example, type: [email protected] in the field.
    NOTE: It is only necessary to configure the DNS settings if Host Names are to be used.
    If Dynamic Addressing has been set on the WorkCentre (DHCP or BootP) the Domain Name will not be accessible. To be able to access the Domain Name, select [Static] from the IP Address Resolution menu list.
  4. Scroll to the bottom of the window and click the [Apply] button to implement any modifications.
  5. When prompted, enter the current Tools mode information in the Username and Password fields.
    NOTE: The default Username is 'admin' and Password is '1111'.
  6. Select [SMTP Server] from under the Internet Services Protocols section.
  7. Select either [IP Address] or [Host Name] and then enter the Host Name, or the IP Address and Port Number (1 - 65535) of the SMTP Server. The default Port is 25.
  8. Place a check mark in the Server Requires SMTP Authentication check box if required.
  9. Enter the Login Name and Password.
  10. Click on the [Properties] tab. The Properties window will be displayed.
  11. Click [Services], click [E-mail Settings], then click [E-mail Setup]. The E-mail Setup window will be displayed with the following list of options:
    • Scan Resolution
    • Attachment Type
    • Output color
    • Date / Time stamp on PDF documents
    • 'From' and 'To' Security Options
    • Auto send to self
    • Specify default Subject field text
    • Specify default Message Body text
    • Specify default Signature text
    • Programmable SmartKeys
    • Choose E-mail / Fax Forwarding rules
    • Choose Confirmation Sheet rules
  12. After making any required selections, click on [Apply
4helpful
4answers
Scan cannot be performed
I also had the same problem with HP Officejet 6310 and after trying all the solutions that I could find on the web, I was almost giving up. Then I found this on HP's IT Resource Center website (author J.Eqbal) and tried it and finally it scanned without the error message.
This error happens only in Network connections.
Get the Ip address of the Printer and open the EWS page by typing i.e http://192.168.1.102...where 192.168.x.x.x is the IP address of the Printer.
On the EWS page click on Network and get the host name and copy it.
go to the following location C:\Windows\System32\drivers\etc...inside etc you will find the host file open it using notepad.
Underneath 127.0.0.1 local host
there might be the Ip address and host name ..which will be different from the current host name...change the Ip address and host name ..save the file.
Try to scan...it will definitely work.
4helpful
KM 3060 Scan Error 2101
Hi Guys,
I was getting the 2101 error as well. I resolved this by placing the IP address of the computer into the "host name" field. Only thing to remember is that your IP address will change from time to time. You will need to assign a static IP to that particular machine or give it a reserved IP address through your switch. Good luck!
Scanning
Follow the instructions below if you run into any configuration problems report back to this site and I will be notified by email.
Scan to E-mail allows a scanned document to be distributed to one or more e-mail addresses. This feature allows e-mails to be sent from the printer directly to an SMTP mail server.
NOTE: This solution assumes Microsoft Internet Explorer is being used as the web browser. Other web browsers may vary. You may need to contact your System Administrator to perform this solution, as it requires knowledge of the network’s email system.
The printer will have to be configured for TCP/IP (IP Address, Subnet Mask, Broadcast Address, Gateway Address). Before you begin, print a System Settings List and make sure the printer has an IP Address and that Internet Services is enabled. See the Related Items below for additional information.
NOTE: An e-mail server must be configured properly and running on the network to perform this solution. The IP Address of the e-mail server is required.
  1. Open an Internet browser window on the workstation.
  2. Enter the IP Address of the printer in the Address field, and then press [Enter] on the keyboard. The Internet Services window will be displayed.
  3. Click on [Properties]. The Properties window will be displayed.
  4. Click on [Machine Details] from the list on the left side of the window.
  5. Enter a valid SMTP Compliant e-mail address in the Administrator E-mail Address field.
    NOTE: When entering the address the SMTP-compliant format must be used, for example, [email protected]. Any replies to e-mail sent from the printer will go to the address specified in the field.
  6. Enter a valid SMTP Compliant e-mail address in the Machine E-mail Address field.
  7. Click on [Apply New Settings].
  8. If prompted for a user ID and password, enter the administrator user ID and password in the fields provided, and then click [OK].
    NOTE: The default user ID and password is admin and are case sensitive.
  9. Click on the [+] next to the Protocol Settings folder. A list of items will be displayed.
  10. Click on the [E-mail] link. A list of settings will be displayed on the right side of the window.
  11. Select the receiving protocol to be used from the Receiving Protocol pull-down menu.
    NOTE: Contact your System Administrator for more information regarding the receiving protocol of your e-mail server.
  12. Enter the IP Address of the POP3 Server in the POP3 Server Address field.
    NOTE: There is no option to set a DNS Host Name for the POP3 Server. Contact your System Administrator if you require additional information.
  13. Enter the username for the POP3 account in the POP User Name field.
  14. Enter the password for the POP3 user name in the POP User Password field.
  15. Enter the password again for the POP3 user name in the Confirm Password field.
  16. Enter the IP Address of the SMTP Server in the SMTP Server Address field.
    NOTE: There is no option to set a DNS Host Name for the SMTP Server. Contact your System Administrator if you require additional information.
  17. Click on [Apply New Settings]. A page will be displayed asking for the printer to be rebooted for the new settings to take effect.
  18. Click on [Reboot]. A 'Do you want to Reboot?' message will be displayed.
  19. Click [OK] to continue with the reboot.
  20. Click on the [X] in the upper, right corner to close the window.
2helpful
2answers
Email Address Problems
You must enter a DNS server on the "Network Settings > TCP / IP" page. If you're unsure of it, try copying your default gateway.
Top Konica Minolta Office Equipment & Supplies Experts
Norman Weimar
Norman Weimar
ZJ Limited
ZJ Limited
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
