SOURCE: cant find headphone socket for rosen in-car dvd player
As far as i know, all Rosen in-car dvd players come with IR (infra-red) headphones so the sound is transmitted that way rather than using a lead from the headphones to the unit, therfore no sockets are neccessary!
Hope this helps....
SOURCE: My rosen Car DVD player
In most of the cases,
this problem is not related to cd.But still get the cd checked in any other
player too, this will confirm the fault. Also try other various cds in the
cd player and confirm. But if the cds not playing in other player too
then its faulty cd.But this is very rare. Most probably the
fault is related to cd player. In the cd player unit there are two main parts.
One is cd spinning motor and other is cd reading lens(its also called
"EYE" of the cd player).But if you hear that cd is spinning but its not
playing,. This clears that motor is working, but its not playing so its the
problem of lens.But if you dont hear any cd spinning noise then both motor and lens problem are there, and any of the one is possible. The lens is not reading the cd,because its got dirty or its
got cracked and faulty. The cd player lens is made up of thin glass and its
very delicate. Many a times dust gets collected on the lens, so the lens stops
reading the cd and it do not play. Some times there is no dirt on lens but it
gets cracked, if by mistake any pressure is applied on the unit or
up-side down cd is placed in the tray or internal
short circuit has occurred. These are few possibilities of lens
not working. But in most cases its dirty lens causing this problem. SO open the
tray by pressing the eject button, then turn of car,
by keeping the cd tray open. Then take air blower
and blow air in the unit. Please remove, if there is any cd in the
tray while blowing air. Just blow air for few minutes. Then take a dry tissue
and clean the cd placing tray externally and then turn the power on to car and see,
if that is helping or not. If the problem is same as
before, then disassemble the unit and clean the lens manually by hand using dry
tissue paper and then see if its helping. But take care while cleaning the lens
with dry tissue , and you doesn't apply too much pressure on lens or any other parts.
Also before removing any screw to disassemble the unit. Take a marker with you
ready. Just mark the position of parts and screws before removing. If you have
a cell phone with web cam in it then take a photo of the internal parts before
moving any parts. Disassembly is not very hard but reassembling is not easy. So
this pictures and marks with help you for reassembly. ----------But
if lens is cracked internally then the lens assembly has to
be replaced. You can get it replaced from local cd /dvd player repair
center. They have these parts with them. --------------- To take apart cd player, you need to remove it out from dash .Check both the things, the cd lens and wiring to the motor, which spins the cd inside the player.This should help.
Thanks. Helpmech.
Also have the same problem would love to get this resolved
