Apple MacBook Laptop Computer  Mac Notebook Logo
A
Anonymous Posted on May 28, 2014
Start up disc is full on my mac book air, what do i click?
Michael Lawing
Level 3:
Master:
  • Apple Master 545 Answers
  • Posted on Jul 17, 2014
Michael Lawing
Apple Master
Level 3:
Master:
Answers
545
Questions
0
Helped
71578
Points
1165
If the disk is full, you'll need to move files elsewhere -- either cloud storage, external disk, dvd, etc... You might also have lots of junk on the machine - delete things you don't need and empty your recycle bin.
1 Related Answer
Anonymous
  • 70 Answers
  • Posted on Apr 20, 2010
SOURCE: Mac book starts with blue screen startup disk full
your disk partition is having problem.if u have not taken backup then boot the system with FW mode with saperate Laptop and backup the data,then repartition the hdd and install freshly
Why is my macbook air a1466 showin a file with a question mark when i turn it on and how do i fix it
http://support.apple.com/kb/ts1440
A flashing question mark appears when you start your Mac Symptoms
If you see a flashing question mark when you start your Mac, it's probably because it can't find the system software it needs to start up. Usually, all you have to do to get your Mac back up and running is remind it where its software is.
Resolution
If your computer starts up normally after a brief delay, you probably just need to reselect the startup disk in Startup Disk preferences. It's normal to see the flashing question mark when a startup disk has not been selected. In most cases, reselecting the startup disk is all that is required to resolve the issue.
Sometimes, your computer may not start beyond the flashing question mark.
Tip: If your computer has a gray screen (with no flashing question mark) startup issue, see Mac OS X: Gray screen appears during startup.
Check the mouse and keyboard
This issue might occur if a mouse or trackpad button is pressed during startup. Make sure the button isn't pressed.
If the issue persists, shut down your Mac with its power button, disconnect any external mouse and keyboard, then turn on your Mac with its power button. If the flashing question mark issue persists, reconnect the keyboard and mouse.
Additional steps
If your Mac still starts to a flashing question mark, follow the steps below. If any step resolves the issue, you don't need to continue to the next one.
  1. Select your Mac OS X startup disk with Startup Manager by restarting and holding the Option key. After your Mac starts up, restart again to verify that the flashing question mark does not appear.
  2. If the issue persists, insert your Mac OS X installation disc. Be sure to either use the disc that came with your Mac, or, if you installed a later Mac OS X version from disc, use the newer disc.
    MacBook Air note: On a MacBook Air, there are two options for starting up from Mac OS X media: Either connect a MacBook Air SuperDrive to the MacBook Air via the USB port and restart the computer, holding down the C key during startup, or use Remote Install Mac OS X to startup from a system software DVD that's located on a partner computer. Once started up from Mac OS X media, skip to step 3.
  3. Restart the computer, then hold the C key during startup.
  4. From the Utilities menu, choose Disk Utility. Don't click Continue.
  5. Select your Mac OS X disk (named "Macintosh HD" by default) in the left side of the Disk Utility window.
  6. Click the First Aid tab.
  7. Click Repair Disk to verify and repair any issues with your Mac OS X startup disk.
  8. After repairing the disk, try to start up normally.
    Important: If Disk Utility finds issues it cannot repair, you may need to back up as much of your data as possible (or use Time Machine to back up to a different disk), then erase the disk and reinstall Mac OS X. You should back up important files and data before erasing a drive. Erasing deletes everything on the hard disk (including things on your desktop). Also, you can install Mac OS X onto an external disk, start from the external disk, and use Migration Assistant to transfer items from your usual internal Mac OS X startup disk to the external disk, then erase the internal disk and reinstall Mac OS X.
  9. If the issue persists, and Disk Utility didn't find any irreparable issues, quit Disk Utility, quit the Installer, select your disk when prompted, and restart.
  10. If the issue continues, reset PRAM. Note: After resetting PRAM, if the computer starts up normally, reselect the startup disk in the Startup Disk preferences.
  11. If none of these steps resolve the issue, start up from the Mac OS X Installation disc and reinstall Mac OS X.
Last
When turning on its saying start up disc is full and have to make space and also now for second time in 2 weeks i clicked on start up disc rebooted and now just have grey screen
When u turn on your PC, press down F6 or F3 ( Different key on different systems to go to setting) once setting page is displayed, select primary boot as Disk instead of CD rom and then reboot. Hope this helps :)
Forgot password for macbook air
Dear Sir,
Welcome to Fixya Support
Resetting Your Password You can reset your administrator password and passwords for all other accounts. To reset your password, using a partner computer and Remote Install Mac OS X:
1 Follow the procedure for using Remote Install Mac OS X
To use Remote Install Mac OS X: 1. Insert the Mac OS X Install Disc 1 into the optical disc drive of the other computer. 2 .If the other computer is a Mac, open /Applications/Utilities/Remote Install Mac OS X. On Windows, choose "Remote Install Mac OS X" from the Install Assistant. 3. Read the introduction and click Continue. 4 .Choose the install disc you want to use, and click Continue. 5. Choose a network connection: AirPort, if you are using an AirPort network, or Ethernet, if the other computer is on an Ethernet network and you have an optional Apple USB Ethernet Adapter connecting your MacBook Air to the same network. Click Continue. 6 .Restart your MacBook Air and hold down the Option key as it starts up, until you see a list of available startup disks. 8. If you chose AirPort as your network in step 5, on your MacBook Air choose your AirPort network from the pop-up list. If the network is secure, you are prompted for a password. You can enter a private network name by choosing the ellipsis (...) and typing the name. 9. If you chose AirPort as your network in step 5, when you see the AirPort status icon indicating signal strength, click Continue in Remote Install Mac OS X.
10. Click Continue in Remote Install Mac OS X. 11. On your MacBook Air, choose Utilities > Reset Password from the menu bar and follow the onscreen instructions. When you finish, quit Mac OS X Installer. 12. On the other computer, click Quit to exit Remote Install Mac OS X.
I think it helps.Let Me know.
My MacBook air webcam stopped worked suddenly.
Check for a failing hard drive
Trying booting from the Mac OS X install disc. insert the Mac OS X install disc. press the start button, while holding down the "C" key on the keyboard
Once you are running from the disc. go to Disk Utilities select the hard drive click the "repair permissions" button at the bottom.
If you get any red errors listed or it doesn't seem to finish repairing the permissions you have a failing hard drive and it will need to be replaced.
2helpful
My Mac Book won't open. I have a gray screen with the revolving wheel and it won't go any farther.
p.p1 {margin: 0.0px 0.0px 0.0px 0.0px; font: 12.0px Helvetica} p.p2 {margin: 0.0px 0.0px 0.0px 0.0px; font: 12.0px Helvetica; min-height: 14.0px}
2helpful
My macbook pro 15 has a problem in "start up". When I push the button I hear a melody off "start up" end come up white screen with apple sign. After second or two, come usual spinning wheel and then...
Check for a failing hard drive<br> <br> Trying booting from the Mac OS X install disc. insert the Mac OS X install disc. press the start button, while holding down the "C" key on the keyboard<br> <br> Once you are running from the disc. go to Disk Utilities select the hard drive click the "repair permissions" button at the bottom.<br> <br> If you get any red errors listed or it doesn't seem to finish repairing the permissions you have a failing hard drive and it will need to be replaced.
3answers
Mac book air cannot start
When troubleshooting a Macbook Air, there is a checklist from Apple Support you need to try.
You are welcome to do so after first trying these steps first.
• Check the Magsafe power adapter, to make sure it is free of debris and is seated properly.
• If with decent charge, try to start the Macbook Air, with only the battery.
If you get power from either one of these issue resolved- otherwise follow the steps provide more in detail from Apple listed in the link below.
Apple Support Link:
Troubleshooting Macbook Air (additional steps)
Such power issues with Macbook Airs as well as Macbook 13" and Macbook Pro 13" are about the same and there are no workarounds, so make sure to follow those procedures completely for a full assessment of your Macbook Air's functionality.
Hope this helps!
Regards,
-Mactechtrainer
I book g4
Some of the start up files have been corrupted or are missing. Start up from the OSX system disc and them run Disc Utilities from the installer toolbar. Check the hard drive for errors. Repair any errors if they are found. If it's not possible for Disc First Aid to repair the hard drive you will need to replace the drive and re-install OSX.
Top Apple Computers & Internet Experts
Paul Carew
Grand Canyon Tech
Grand Canyon Tech
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
