Model, C24 cyclone. I have cleared the brush of threads but the reset button pops out after just a few seconds of use. This happens all the time
SOURCE: On the DC07, the entire cyclone assembly must be
Beofre you go to the extent of buying a replacement canister, you can remove the top and using a straightened coat hanger type thing open that bottom lid. Then maybe you can clean the rim and possibly add some silicone spry to loosen things up. Here's how to get inside In this order: 1) Remove the canister 2) remove the three star screws at the top of the canister. It'll take a bit of pressure to pull the top up, there's a rubber seal. When you pull it up there will be a rod running down into the canister, leave it be, just pull up the top high enough to clear out any debris. 3) Use a straightened coat hanger and with a flashlight to guide you, reach down with it and push it into that hole down at the bottom center of the canister. That will pop the lid open. Clean the canister & lid rims, maybe add some silicone. At this point you might as well clean the canister too. OPTIONAL-> ***leave the bottom lid open*** and follow the rest of these steps 4) Put the top back on aligning the screws, when you lower it make sure the bottom of the rod engages with the hole at the bottom center of the canister, this is why you left the bottom lid open. Put the three star screws back in. 4) Turn the canister upside down, lid open, and keeping in mind this is thin plastic, gently tug upwards on the four fins that surround the bottom rubber seal. This part is held in by friction, so work your way around the four fins gently pulling until you work the ring they're connected to free. This will give you access to the inside of the canister. 5) remove the round perforated section by tugging upwards on it, set it aside with the fin part. 6) Take the canister to a laundry tub or large sink and holding it bottom up fill it with hot/warm water. Grasping the center section shake it vigorously and turn it upside down while shaking and a bunch of sh*t will come out. Repeat several times. 7) Dry thoroughly, you might use a hairdryer held to the center tube, but only if you can switch off the heat and use air only. Make sure its 200% dry, water will kill your machine 8) clean and replace the round perforated section 9) replace the fin section, I'd suggest pulling the round rubber part off of the fin part and setting it in place on the canister first, then follow with the plastic fin part. If you don't do it this way the rubber won't seat properly and the bottom lid won't close. 10) Close the lid, replace the canister, and staaaaaart suckin like it's brand new.
SOURCE: Dyson DC 28 Brush Bar spins < 5 secs and then red light activates
Is the machine not turning on? There may be a push button circuit breaker on this machine but I doubt it. I have no personel experience with this specific device. Are you sure you have power going to the sweeper? All guards, filters and shields are in their proper place?
Let me know
a
SOURCE: carpet cleaning brush noise
It's likely that one of the brush roll bearings has worn out. This is not uncommon. I think you'll find that you have to replace both the brush roll and the sole plate at the same time. Dyson sell them together as a kit.
SOURCE: dyson dc05 takes the dirt up the cyclone cone
Hi its Darran at Dyson.
From your description of the problem, it sounds as though the bin inner is missing. If you remove the bin and cyclone assembly from the machine and then seaprate the two pieces as if you were going to empty it, you should have a coloured piece of plastic in the bottom of the clear bin with a large black rubber seal around the top. If you dont, you will need to purchase a new bin assembly via our website at www.dyson.co.uk or via our Helpline on 0800 298 0298.
Kind regards
Darran
Dyson Customer Service
SOURCE: dyson animal dc07 does it have a reset button?
The reset button is incorporated into the on/off switch for the brushroller which is the grey button next to the red power button. Try hitting that button separately.
