A
Anonymous Posted on May 28, 2014
How do you fix a crossfader problem with a numark M6 usb mixer
Dj Phat Kid
Level 1:
  • Contributor 1 Answer
  • Posted on Nov 05, 2014
Dj Phat Kid
Contributor
Level 1:
Answers
Questions
0
Helped
620
Points
0
Replace it. I'm on my second one. http://www.instrumentalparts.com/xf-m6usb.html thinking of getting another type of mixer.
Hey . just wondering how do i connect my phonic max 2500 amp to my Numark M6 USB mixer. then i will be connecting my laptop up to the mixer..
The M6 has balanced XLR outputs on the back, which can be connected directly to the XLR inputs on the back of the Phonic Max 2500. You just need two XLR cables.
I canot figure out how to play songs in my computer on my mixdeck
Just connect MIXDECK to your Mac or PC with a single USB cable and you're seamlessly controlling the music on your computer. MIXDECK's MIDI communication enables you to easily map virtually any DJ software for direct connection from your fingers to software.
MIXDECK's USB connection also can receive two stereo audio channels from your computer, empowering you to mix software audio with CD tracks.
The mixer channels control the audio from MIXDECK's onboard players, incoming audio from your computer, or external sources such as turntables, MP3s players and more. MIXDECK has two sets of stereo, switchable phono/line inputs for external sources. MIXDECK's replacable crossfader has switchable slope and reverse so you can customize its performance based on your preferences.
1helpful
What lube can i use to clean numark nuvj crossfader. i'm gettin a leak while using the fader.
Usually a "leak" from one side to the other is an indication of a cracked resistance element. The fader would have to be replaced.
I lube the faders on my mixers using CRC226 availablle in the electrical dept at Home Depot. Use sparingly.
I have a Numark C2 19" mixer. I am missing one of the small screws right next to the crossfader and need some replacements. Where can I get them and/or what size are they so I can buy them at my local...
They are LIKELY metric and the best way is to remove another and take it as a sample to a hardware store.
Use a nut to find the correct size thread and then find the matching screw and right length.
3helpful
2answers
The crossfader won't gradually fade from deck to deck.
In the front of the IDJ2 system there should be a switch labeled "CF Slope." Switch it downward and you should be good.
How do I replace the crossfader on my Numark 5000FX mixer
Hi Dannyyoung
Remove the face plate of the mixer (7 Philips screws) and remove all the knobs and any pot retaining nuts. The you will then be able to get access to the fader to replace it. Any dramas, fell free to ask away
regards
robotek
Tapco MIX60 6-Channel Mixer
It does not appear to have a crossfader
Check this link for a closer look at the mixer. You can click the "larger image" link and get a really good look at it. Unless one of the knobs are a crossfader, but I always seen sliders as a crossfader. At least you can see it better here.
http://www.bswusa.com/proditem.asp?item=MIX60
Top Numark Audio Players & Recorders Experts
 Grubhead
Grubhead
ADMIN Andrew
ADMIN Andrew
Are you a Numark Audio Player and Recorder Expert? Answer questions, earn points and help others
