I can print a single piece of paper through the manual feeder slot. Printer prints great! It just won't print using the bottom tray.
SOURCE: Dell 3100 CN printer...message on printer reads load tray
Cycle Power on the Printer
Verify There is Paper in the Tray
Verify the Paper Size
Look at the chart below to verify that the paper size meets the 3000cn /
3010cn / 3100cn-series specifications.
Verify the paper size in the tray matches the size set in the 3000cn / 3010cn
/ 3100cn-series printer´s operator panel.
To verify the paper size in the tray matches the size set in the printer's
operator panel, perform the following steps:
*1 Denotes country-specific factory default values.
*2 Available for the optional 250-sheet cassette only.
Figure
1 - Paper Size Chart
Verify the Paper Type Matches the Type Set in the Printer´s Operator
Panel
To verify the paper type matches the type set in the printer's operator
Table 1: Paper Type Chart
All media types that are not Plain 1 should be printed from the
MPF only.
Verify the printing preferences on the Dell™
3000cn / 3010cn / 3100cn / 5100cn-series printer.
To verify the printing preferences is set to print from the correct tray with
the correct paper size, perform the following steps:
The Printers and Faxes
window appears.
The
Printing Preferences window appears.
This sets the size and tray
defaults.
Verify the Paper Size From the Printing Application Matches the Designated
Printer Tray
To verify the paper size from the printing application matches the designated
printer tray, perform the following steps:
Verify the Paper Source From the Printing Application Matches the Designated
Printer Tray
Do not replace any printer hardware as this is not a printer hardware
issue.
SOURCE: Will not print
This usually happens when the paper tray is set to the incorrect paper size.
This printer determines what size paper is installed in it by the little "fingers" on the left side of the tray. When you adjust the paper tray, it determines how those fingers are positioned, and therefore, how the switch reads the paper size.
If the tray setting is off, even by one little click, then the machine may read the paper size as other then letter. If this happens, you send a letter size job to the printer, and it doesnt think it has letter size paper, it will tell you to put letter paper in the MPF feeder.
If the tray is definately set to letter, but the machine still thinks it does not have letter, then the tray or the switch that reads the tray is defective, but 99% of the time it is just the tray is not set correctly.
The MPF door can be open or closed 100% of the time with NO EFFECT on how the printer works.
Testimonial: "Absolutely useful although I didn't see it when I worked it out by my own."
SOURCE: Dell s2500 printer - multipurpose feeder not taking paper - never been used
I had the same problem and resorted to making sure that there were several envelopes in the tray -- and hand feeding them. I suspect we both have a pickup roller problem, which is typical of the printer, and is the source of a lot of phantom jams.
SOURCE: I have 2 Dell model 1700n laser printers and they
Take off the two rubber rollers, turn them inside out and replace them, Voila!
