LG WM-2277HW Front Load Washer Logo
m
malcolm huscroft Posted on May 28, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Lg 1370 slight clean water leak on left side of dispenser draw sometimes? solutions please ,
Clean water leak left hand side of dispenser draw, now and then, usually on heavy loads
Paul
Level 2:
Sergeant:
  • Expert 381 Answers
  • Posted on May 29, 2014
Paul
Expert
Level 2:
Sergeant:
Answers
381
Questions
0
Helped
146050
Points
960
Usually a sign that you are using too much detergent. Pull the drawer out completely and clean it out. The drawer and the casing
5 Related Answers
Anonymous
  • 489 Answers
  • Posted on Jul 23, 2008
SOURCE: LG washer leaking problem
You may be using too much detergent.  Use only 2 tablespoons of detergent in your wash.  Using too much will oversud the machine causing the suds to go out the back vent and on to the floor giving the sense of a leak.
On the dispenser, make sure that the containers are clean and free of any debris.
Anonymous
  • 60 Answers
  • Posted on Aug 15, 2008
SOURCE: Bleach not always being emptied, bleach marks on clothes, bleach sometimes runs right out when you fill it.
The dispenser works on a siphon principal. If you over fill the cup it will start the siphon and empty before it should. If that's happening you're using way too much. You only need about a tablespoon of soap, softner and bleach for a full load.
Anonymous
  • 236 Answers
  • Posted on Mar 16, 2009
SOURCE: LG WM2688HM front loader is leaking water around the door seal
this may be coming from the soap dispenser and running down round the door way and to the bottom- investigate that first. otherwise the seal may be worn/ damaged and needs replacing.
Anonymous
  • 15 Answers
  • Posted on Apr 18, 2009
SOURCE: lg front load washer leaking from bottom of machine
I just fixed this problem - there is a rubber hose that hooks the bottom of the drum to the drain and recycle pumps - it is ribbed and it developed a hole. To confirm and repair (repair can be done from the front of the machine)
  1. Unplug the machine.
  2. Drain whatever water you can from the machine using the stoppered hose behind the bottom left panel
  3. Unscrew the visible screw holding the plastic in place near the drain hose and filter
  4. If you can pull the plastic recessed piece out, there is one screw visible behind it - unswcrew this. If you cannot pull it out now, you should be able to get it after you remove the screws in step 10
  5. Pull out the detergent drawer (push in the middle back "botton" to release the drawer to pull out fully)
  6. Unscrew two screws in the drawer area.
  7. Pull the top of the electronics assembly away from the machine and lift the assembly out (place on top of the machine or hook it out of the way)
  8. Open the door and remove the spring loaded wire around the door seal (be careful as the seal can be torn)
  9. Pull the seal away from the metal front panel, then close the door
  10. Remove four screws at the top of the front panel (that were behind the eletronics assembly) - If you already have removed the screw from step 4, proceed, otherwise lean the top of front panel out and pop the plastic out, hold panel in place and remove that bottom screw from step 4.
  11. Lift front panel about two inches, swing the entire front panel to the right and set against something - You should now be able to see inside the machine.
  12. There is a black hose right in the middle - when I squeezed mine a little, I could see where the water was dripping out from the bottom.
  13. There are three clamps - two that can be squeezed with pliers and removed, one that has to be unscrewed (phillips head screw - it is a bit blind as the screw faces the back of the machine) - Once I got mine off - I could see the hole.
  14. Order replacement and reassmble in the opposite order
Anonymous
  • 15 Answers
  • Posted on Apr 27, 2009
SOURCE: LG WM2487 Leak Front Left
Not sure if this machine is similar to the WM2277, but here is the procedure for that - my leak was in the "baffels" hose that connects the drum to the drain pump:
1. Drain the machine - pry the panel at the front left lower corner to get access to a stoppered tube. drain as much water from here as possible.
2. Remove screw visible inside this area and remove the white molded plastic - also remove the screw behind that plastic.
3. Open the washer door and remove the spring loaded wire around the door gasket. Carefully pull the door gasket away from the panel push inside and then reclose the door.
4. Remove the detergent drawer and the two screws visible behind it.
5. Pull the top of the electronics panel away from the machine and lift up - place on top of machine or hook it out of the way
6 Remove the 4 screws that are visible holding the front panel to the machine. Left the entire front panel up about 2 inches and swing to the right (there is a wire connecting the door to the machine on the right)
LG WM3500 - Leaking dispenser drawer with Failed Valve
Sounds like you should buy a water filter to put in your house or wherever line to filter the water. it can be a cheap one with just a cheap paper filter to keep out any sand or settlement especially if you are on a well oh sounds like the valves are getting dirty inside and not closing completely because of debris in the valve.
Whirlpool cabrio platinum model #WTW8000WB0 UL code even when washer is empty & also sometimes the fabric softener dispenser is half full of clean water after complete wash cycle
Simplest answer is a blockage in the pipe from the dispenser to the Drum.
If you take out the dispenser draw, sometimes little tricky, there is normally a lip at the back that stops you pulling it out accidentally, you just need to depress this or wiggle it out. once out Clean it, some dispensers have a cap over the softener dispenser. you should be able to pull this off, if it does not work, put in the sink and poor warm water down the whole on the other side of the softener dispenser.
Once water flows through, clean the rest of the draw and where the draw fits and pop it back in and you should be good to go.
Keep it clean, say once every few months.
2answers
Leaking water from front of door. Replaced boot seal but still leaking. It looks like door is kicked out at the bottom. Would replacing the hinges help?
Try turning the water pressure down. If you have high water pressure the water comes into the dispenser to hard and splashes over the front & side of the dispenser draw the trickles down the inside of the front panel out on to the floor. Very common front loader problem.
My hotpoint wmud843p washing machine is leaking from the detergent draw at the start of the rinse cycle?
Open the draw. Grip it tightly and pull it out. clean the draw and clean the dispenser housing. Usually leaks due to powder etc getting stuck under dispenser draw causing water to bridge across and leak under draw. Also use a pipe cleaner or cable tie to clear any blocked holes in the dispenser.
1helpful
3answers
Water will not stop flowing in to icemaker
Dirt in body of icemaker water supply valve. OR. Ice maker timer stuck when it selected "add water to icemaker.
The first solution is simple, change icemaker water filter and disassimble valve to clean.
The second is simple, buy a new icemaker.
2answers
LG Tromm - WM2688HNM - Detergent dispenser full of water & some detergent after wash.
Even though you want your washer completely leveled, you need it to be leveled but slightly tilting to the back.
We were having this issue after we releveled our washer because of vibrations during the spin cycle. Once we made a slight adjustment, the problem was solved.
2answers
Water leaking out slightly from detergent dispenser draw and is starting to rust down left hand front side of machine,checked all water supply and drain hoses but leak appears to be coming from high up...
Your water pressure may be a liitle too high for the machine to handle. Try turning the water valves for the hot and cold water down a bit to reduce the pressure and try it again.
Cleaning Solution leaks out around bottom
Most likely the opening under the seal has cracked or is starting to break away. You will have to replace the water bucket, the soap dispenser come with it, not separately.
2helpful
2answers
Fabric Dispenser
The detergent dispenser is located above the detergent drawer. A water pipe is connected to it and water entrance and distributed to drawer's cells (following the programmed cycle) by a lever's movement (part of the dispenser). The lever movement is controlled by two solenoids that received their power from the timer. By opening upper machine's cover you will have an access to the dispenser. Disconnect the power cable from the machine before moving to next test !!!! Look first that they are not any disconnected wires. Move manually dispenser's lever and see if water running to all cells (depend on your movement). In case it doesn't work properly remove the unit from the machine and try to clean it (I hope it will help, otherwise you should replace the unit). In case it works properly (manually) - you should test by a multi-tester solenoid's resistance. the one that doesn't have a resistance measurement should be replaced. Good luck !!
Top LG Washing Machines Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
