SOURCE: mercury sable 2004
Depends on the sound that it makes when you turn the key over.
Clicking noise...usually the starter
If it sounds like its going to start, but doesnt, most likely the battery.
If you have replaced the battery recently, then its the alternator.
Sometimes there can be oil build up over the spark plugs so it doesnt get the spark to start.
Hope you get it fixed!!
SOURCE: 2002 mercury sable heater wont get hot
you have a broken or stuck temp blend door in the heater case. or the servo motor is broken. this sits on top of the heater case
SOURCE: Check charging system icon keeps coming on
I had the same problem with a 99 sable and it was the drive belt
SOURCE: 2000 MERCURY SABLE
My 2000 Sable starts blowing hot air about every 6 months. I mean like an oven. All I do is disconnect the battery negative terminal for about 5 minutes. After I re-connect the problem is solved. This solves many problems on this car, it just needs a re-boot. It must be powered by Microsoft (ha ha). Good luck. ps my auto headlamps never did work right either. Dave.
SOURCE: how to reset the air bag sign staying lit on the
Usually disconnecting the battery for anywhere from 10 - 30 mins resets any codes stored in memory.
Sometimes however it is a specific amount of "key cycling" that is required. eg: Turn key on, then off, then on for X seconds, then off for X seconds, then start engine etc. etc. etc.
If you have disconnected the battery, and there are no codes present but the light still comes on, there could be an issue with your airbag system. Wiring, or something was not done right.
WARNING : If you intend to work on the airbag yourself remember to disconnect battery for at least 45 mins. The air bag requires approx. 20-60 mins (depending on the vehicle, make and model and year) to discharge. If you do not do this you risk deploying the air bag, and that could ****!
