Would you recommend purchasing this used?
SOURCE: Miele 2470 does not rinse
Hi dear.According to what you're saying,there is a problem with wash pump.Please do this before take any action, remove the filter & check for any obstacles.if there is any clean it & run the machine for test.If this did not work then there is a little capacitor on the main wash pump.That's causing the problem & needs to be chage.If you can do it,try to replace the capacitor "?uF"same as the original type.It should work perfectly.I hope that helps.Thanks.
