SOURCE: Cuisinart by the cup burns 8 out of 10 times
Go ahead and replace the charcoal water filters on the Cuisinart- they are usually available at Bed, Bath and Beyond. Before you insert the new filters, run a pot of water only through the coffee maker with 2 tsps lemon juice per cup of water. Also, make sure you don't use the 1-4 cup setting - it actually double-heats the water. Hopefully, this should resolve the issue. Good luck!
-Tha Mp3 Doctor
SOURCE: hi there. all of a
Most appliances oof this type have a thermal fuse somewhere in their circuitry that blows is the machine gets too hot. I'd suspect this. It is fixably by DIY types, if you can get into the machine circuitry, but that is sometimes very difficult in modern appliances. A good appliance repair shop should be able to fix it easily.
SOURCE: my cuisinart espresso maker seems
take it back and watch them and then do it yourself a few times while you are there
SOURCE: cuisinart espresso maker
One question: have you tried the machine without the porta-filter attached? If it works through an entire cycle without the porta-filter attached, then the porta-filter is clogged. I've lost that special little tool to poke into the hole on the porta-filter, but a fine-tipped needle works just as well. Other pins that I've tried are too thick. Sometimes there's a piece of coffee that has made it through the top part of the filter gets stuck at the single hole that is the exit. Find an appropriate pin and poke around with it, then run WATER only through the filter. If it makes it through a cycle, you've fixed it. This clogging can happen very frequently with too finely ground coffee.
If however, your machine stops and beeps without a filter attached, then there's something restricting the flow inside the machine and your only alternative is vinegar, or similar decalcifier.
