Unable to set time
The time on this watch is set by changing the digital display time then transferring the digital time to the hands.
1 - Turn the crown until the mode hand points to the time mode [TME].
2 - Press either button (A) or (B) to select the city for which the time is to be set.
3 - Pull the crown out to the second click (3) to enter time setting mode.
4 - Pressing button (A) will change the digits to be set. These digits are the ones that are blinking. Press button (A) to select the digits that you want to change.
When button (B) is pressed in the [SMT] daylight savings time correction mode, DST can be turned ON or OFF.
When button (B) is pressed with the seconds digits blinking, the seconds will return to "00".
5 - Turn the crown clockwise to advance the hours or minutes when those digits are blinking.
Although the crown may be turned in either direction, you should always turn it clockwise to the final setting.
6 - When the 12H/24H selection is blinking, pressing button (B) will turn it On/Off.
7 - After correcting the time on the digital displays, push the crown in to normal position (1) to complete time setting.
i think this may solve ur problem
thank u.................
