You could find the manual on the internet by google. Im afraid that it's possible that it possibly broke the disc drive or the part of the drive that automatically loads and ejects the disc.
Unfortunately this is a hardware problem, aka an issue with the Wii's inner components. In the disc loading tray there is a photo cell sensor that reads when a disc is present within the Wii. This sensor is most likely off center and giving false readings, therefore it is rejecting the discs you load into it. Another issue could be that the disc loader's ribbon cable is loose/not correctly attached to the rest of the Wii.
You will have to get the Wii fixed by Nintendo or you will need to buy a new Wii system. Hopefully you still have a Nintendo warranty for the system. Registering your Wii system on club.nintendo.com can add an additional 90 days to your Wii's warranty.
With the Wii Console vertical, the discs should be loaded with the shiny side to the left. If you are loading like this and all discs are being ejected, then you very probably have a problem with the Wii Console.
To ck into repair go here:
http://www.fixya.com/ThreadView.aspx?thid=2204194&prdid=618512
If Wii gives Disc Read Error, first step you need to check is to try another
disc or clean the exisitng disc. This will confirm that problem is with either
Wii or Disc. If the console itself is giving disc read error then it needs to be
repaired. You may check out DIY Wii Fix Guide, that
will show step by step information to fix the problem yourself. It also gives
information on fixing many Wii Related Problems, so its a kind of Wii Problems
Reference Fix Guide....
another disc or clean the exisitng disc. This will confirm that problem
is with either Wii or Disc. If the console itself is giving disc read
error then it needs to be repaired. You may check out DIY Wii Fix Guide,
that will show step by step information to fix the problem yourself. It
also gives information on fixing many Wii Related Problems, so its a
kind of Wii Problems Reference Fix Guide
The lens in your wii disk drive might be dirty or scratched. Try putting in a regular head cleaning cd. The problem is that the wii will not read it but it might spin it round enough while trying to read it to clean the lens. You could also do it manually by taking your wii apart but i wouldn't recommend it personally due to the large quantity of things that break easily and the amount of screws to be taken out that are easy to lose.
