Washing Machines Logo
Posted on Jun 24, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
TROMM Washer "CL" Error Message
I have a TROMM DD-Inverter 7kg WP-87000 front loading washing machine. Mysteriously, because it wasn’t in use at the time, the washer started displaying the error message “CL.” Can anyone help diagnose this error message and its related problem? I have inherited the machine from the previous owners and don’t have the washer’s owners manual. Many thanks!
  • Mayomi Ayo
    Mayomi Ayo Mar 14, 2016
    CL.....means closure......u have to unlock the safety child lock
David R Sannicolas
Level 2:
Teacher:
An expert who has written 2 tips or uploaded 1 video tip.
  • Expert 42 Answers
  • Posted on Feb 13, 2010
David R Sannicolas
Expert
Level 2:
Teacher:
Answers
42
Questions
5
Helped
24215
Points
119
THE CL ERROR CODE IS CHILD LOCK, PRESS AND HOLD THE PREWASH BUTTON FOR 3 SECONDS AND IT SHOULD TURN OFF........ BUT IF THERE ARE OTHER BUTTONS TO PRESS TRY IT OUT, THE OLDER LG'S HAD TWO BUTTONS TO PRESS, SO IF YOURS ARE THE OLDER ONES TRY IT OUT..... IF THIS HELPED OUT, PLS LEAVE A FEED BACK. I DO NOT ACCEPT PAYMENTS FROM ANYONE ONLY FEED BACKS, IT MOTIVATES ME TO HELP OUT OTHERS WHO NEEDS HELP....................
  • 1 more comment
  • joannalazuch Feb 16, 2011
    Thank you very much ,it works I am new to lg washer and it was my first washing experience with this mashine. Thanks, Thanks!
  • mh_imam Sep 06, 2011
    Thank u so much. I've tried your suggestion and solve CL problem.
    Thanks once again...
    M.H. Imam, Ranchi
  • Channa Marambe Oct 15, 2013
    thank you david sannicolas! save me lot of trouble!
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Dec 28, 2009
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1260
Points
Hey did you ever figure this out?? I, too, just got this message in my inherited, manual-less washer. Already cleaned out the lint thing in the bottom right corner, and found a bunch of bobby pins about about 600won. But the CL won't go away.
Tedowen
Level 2:
Prodigy:
An expert who has answered 500 questions.
  • LG Expert 536 Answers
  • Posted on Mar 16, 2016
Tedowen
LG Expert
Level 2:
Prodigy:
Answers
536
Questions
0
Helped
264779
Points
943
On this particular machine the CL child lock is disengaged by pressing the Prewash button for 3 seconds.
6helpful
2answers
LG Tromm washer, what does error code ''CL'' mean?
Hello there and welcome to fixya
THE cl is not a error code at all
it SIMPLY MEANS THAT THE CHILD LOCK FEATURE HAS BEEN ACTIVATED
not to dismiss the feature simply press and hold the wash and rinse buttons for a minimum of 5 seconds and release Your machine may be different so you may have to press a different series of buttons like if theree are 2 buttons with the unlock or lock picture on them or shows a child or something like this but it should be 2 buttons that are neded to unlock ok
Hope this is very helpful
Best regards Mike
2helpful
It showing cl on the screen
Hi
Thanks for using FixYa. CL means child lock, it might have got locked. Try pressing "dry" & "spin" together for a 10 seconds or until the CL disappears. Also try pressing "end of cycle" for over 5 seconds.
If this doesn't work then try pressing "options & select" till the light goes off.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
8helpful
3answers
Message CL has appeared whch is child lcok. How
hold down the rinse and prewash buttons at the same time for 3 seconds , do the same to start it also.
26helpful
Lg intello washer error code cl
fault code "cl".you have your child lock function on.push the two child lock buttons together on the control panel,hold them for a few seconds till the "cl" icon dissapears
1helpful
LG Sense Clean DD error code "FE" front loader washer/dryer combo
my lg senseclean wash mashine shows the sign Cl on the display and the door cannot be open what does it mean?
3answers
Tromm washing machine, front load from LG
Peace,
ngafm at your service!
Lets try this first!
Did you try to open the door when the breaker was off or only when you turned it back on??
How old is the washer?
I'm here all night if you want to write me back!
Bless You,
Please leave me a good rating in this site before you sign off!
7helpful
2answers
Error Message CL in the front panel
Error message CL solved. CL means child lock. To deactivate press two linked buttons (on my machine the right options button and the temp button) together for a couple of seconds.
Top LG Washing Machines Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
